Related rates question, shadow
shanshan
A man 6m tall walks away from a light 10m above the ground. If his shadow lengthens at a rate of 2m/s, how fast is he walking?
I have nothing.
Using similar triangles you can find the relationship between the shadow length (B) and distance away from pole (A).
Keeping in mind that you are given dB/dt and asked to find dA/dt
but how can i use similar triangles if i only have one of the dimensions of the triangle?
Look at the picture I attached. The relationship between ratios is constant, therefore the relationship between speed of man and length of shadow is constant
ahhhh and the light goes on. thankyou!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
