To determine the inductance of a solenoid with 650 turns, a length of 21 cm, and a radius of 4.2 cm, the correct formula is L = μo*N^2*A/l. The area of the circular cross-section should be calculated using the formula A = π*r^2, which was initially miscalculated. After correcting the area to approximately 0.00555 m², the inductance was recalculated, leading to a final result of approximately 22.4 mH. The discussion highlights the importance of using the correct area in the inductance formula for accurate results.
