Which resistor has most current?
  • Thread starter Thread starter Linus Pauling
    Current Resistor
The discussion centers on determining which resistor has the most current in a circuit with an 8V battery, a 12 ohm resistor (R1), and a combination of resistors (R2, R3, R4) with values of 4 ohms each. The equivalent resistance of R3 and R4 in parallel is calculated to be 2 ohms, leading to a total of 6 ohms in series with R2. According to Kirchhoff's loop law, R2, R3, and R4 share the same current, but the current through R3 and R4 is split, making R2 the resistor with the most current flowing through it.
  • Understanding of Ohm's Law
  • Knowledge of Kirchhoff's loop law
  • Ability to calculate equivalent resistance for resistors in series and parallel
  • Familiarity with basic circuit analysis
  • Study the application of Kirchhoff's laws in complex circuits
  • Learn how to calculate equivalent resistance for multiple resistors
  • Explore current division in parallel resistor circuits
  • Investigate the impact of varying resistor values on current flow
Electrical engineering students, circuit designers, and anyone interested in understanding current distribution in electrical circuits.
Linus Pauling
Circuit: Here's the circuit: there is a 8V battery. The charge leaving it reaches a junction: if the current "turns right" it goes to a 12 ohm resistor (R1) and can then loop around back to the battery, if it goes straight (i.e. takes other path at junction) it runs into a 4 ohm resistor (R2). After the 4 ohm resistor, there are two more 4 ohm resistors (R3 and R4) in parallel (i.e. the equivalent resistor of these two is in series with the first 4 ohm resistor).
Question: Which resistor has the most current going through it?
Relevant equations: resistors in series and in parallel, Kirchoff's loop law
Attempt at solution: If I solve the equivalent resistor for the two 4 ohm resistors in parallel, it's 2 ohms, which is in series with the other 4 ohm resistor, giving 6 ohms. This is less than 12 ohms, so the path "straight ahead" described above (i.e. NOT the path leading to the 12 ohm resistor) is the path of least resistance. Since the first 4 ohm resistor is in series with the equivalent resistor of the other two that are in parallel, then they must have the same current flowing through them by the loop law...
So I was thinking that R2, R3 and R4 would all have the same current through them, but my multiple choice options only include R2, R3, and R4 individually or R3 and R4 together.
R2 is in series with the equivalent resistor r3//r4, so the same current goes through them, but this does not mean thant the same current goes through r3 or r4.
Consider the point that connects r2, r3 and r4. The ingoing current through r2 must
be equal to the sum of the outgoing currents through r3 and r4.
  • · Replies 18 ·
