How Can I Generate Two 1024 Bit Prime Numbers Using the AKS Primality Test?
The discussion revolves around generating two 1024-bit prime numbers, specifically exploring the use of the AKS primality test and other methods for primality testing. Participants share various approaches, algorithms, and considerations related to the task, including theoretical and practical aspects.
  • One participant seeks guidance on generating two 1024-bit prime numbers and mentions the need for algorithms to assess primality.
  • Another suggests searching for information on primality tests, mentioning Rabin's test as a potentially good option but without certainty.
  • A participant proposes using a database of known primes if computational capacity is high, but questions the feasibility of this approach.
  • Concerns are raised about the sheer number of 1024-bit primes, with one participant estimating around 2^1014 primes less than 2^1024.
  • Discussion includes the probability of a randomly chosen number near 2^1024 being prime, estimated at about 1/1000.
  • The Rabin-Miller test is highlighted as a useful probabilistic test, with the option to follow up with the Elliptic Curve Primality Proving algorithm for guaranteed results.
  • One participant mentions using Fermat's Little Theorem for finding probable primes, though acknowledges its limitations with pseudo primes.
  • Another participant suggests the AKS primality test as an alternative, noting a lack of existing software implementations.
  • There is a mention of the RSA encryption algorithm and the potential use of pseudo primes, despite their known limitations.
  • Participants share links to resources and implementations related to the AKS test and other primality testing algorithms.
Participants express differing views on the effectiveness and practicality of various primality tests, including the AKS test and Fermat's theorem. There is no consensus on a single method for generating the required prime numbers, and the discussion remains unresolved regarding the best approach.
Limitations include the uncertainty about the efficiency of the AKS test compared to other algorithms like ECPP, and the potential issues with using pseudo primes in cryptographic applications.
Anzas
im making an algorithm in which i need to generate two 1024 bit prime numbers, is there a way of doing this? i read that there are some ways to see how probable it is that a number is prime, can you guys point me in the right direction?
I would do a google search on the keywords prime (or primality) + test (or testing). Looking for a mathworld or wikipedia page on it is probably good.
There is a really good primality testing algorithm, but I don't know its name. I think Rabin's test is a good one, but don't quote me on that. :smile:
Well, if you have giant capacity but only normal speed, you could just look up a database which is sitting on your hard drive ?
I don't think you grasp just how many 1024 bit primes there are!
Can't you just download the PGP source (http://www.pgpi.org/) and see which algorithm it uses to get its prime numbers? I can't remember off the top of my head and am about to run to the beach. Be back later.
- Warren
I didn't really think very much about this and - that's why people don't do this, I guess - that's why I punctuated that line with a question mark instead of a period.
I imagine there would be about 2^1014 primes less than 2^1024 ?
2^1014 is about the right order of magnitude.
You expect the probability a randomly chosen number near 2^1024 is prime is something like 1/1000.
The Rabin-Miller test is usefull, and can tell you a given number is prime with whatever probability you like (the closer you take this probability to 1 the more sure you are it's prime, and also the longer the algorithm takes).
Once your number has passed Rabin-Miller, you can send it into the Elliptic Curve Primality Proving algorithm (ECPP) which can certify that your number is prime (or determine it's composite). This takes longer than a probabilistic test, but if you want guaranteed security, it's the way to go.
You should be able to find many versions of both these algorithms (and many others) online.
i think i found a way to find probable primes using Fermat's Little Theorem...
if i want to check the number "n" for primality
i pick a number "a" such that a < n
and if
a = a^n mod n is true then n might be prime (i need to try sevral "a" values to have higher probability)
fermat's little theorem fails for some numbers (these are called pseudo primes but they hold no interest to whatever u are doing).
One could go with shmoe's suggestion or try AKS primality test (dunno of any software using this one yet so u could be the first :D)
Check this page for a lot more interesting stuffs
http://www.utm.edu/research/primes/prove/index.html
-- AI
well I am trying to implement the rsa encryption algorithm so i think pseudo primes should do as well even though they won't work with some values most chances it will work fine
Anzas, you can download pgp for free.
well pgp is written in c and I am programming in visual basic
porting it would actually be more work then writing it from scratch
several implementations:
http://fatphil.org/maths/AKS/#Implementations
There have been many improvements to the algortihm since AKS first appeared, but I don't think any of them are faster than the best implementations of ECPP for practical purposes.
  • · Replies 21 ·
9K
