From Charge Density -> Electric Field(r) using Gauss
The problem involves deriving an expression for the electric field as a function of radial distance, r, from a given charge density distribution defined by [rho] = [rho]_0 * e^(-r/a). The context is rooted in electrostatics and Gauss' Law, with a focus on understanding the relationship between charge density and electric field in a spherically symmetric system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the implications of Gauss' Law in relation to the charge density and its contribution to the electric field. There are attempts to integrate the charge density over a volume to find the total charge inside a radius, with some participants expressing confusion about the integration process and the role of spherical symmetry. Questions arise about substituting volume in the context of a non-constant charge density.
The discussion is ongoing, with participants sharing their thoughts and attempts at solving the problem. Some guidance has been provided regarding the integration of charge density and the application of Gauss' Law, but there is no explicit consensus on the solution yet. Participants are encouraged to explore the integration process further.
There is a noted difficulty among participants with the integration aspect of the problem, particularly in applying mathematical concepts to physical scenarios. Some participants express a desire for clearer explanations and examples to aid their understanding.
zSanityz
"Consider a charge density distribution in space given by [rho] = [rho]_0 * e^(-r/a), where [rho]_0 and a are constants. Using Gauss' Law, derive an expression for the electric field as a function of radial distance, r. Sketch the E vs. r graph.
Was a question on a quiz that I messed up, curious now on how to do it properly so I'm more prepared for the quiz, and teacher is out for awhile.
These are the equations I know that seem relevant, probably not all useful though:
[rho] = q/V or [delta]q = [rho] * [delta]V
[del] dot E = [rho] / [epsilon]_0 or [line integral]E * [delta]A = Q/[epsilon]_0
I have no idea how to start this thing, and what I should be pursuing. I know it should end up as some sort of hyperbole, since that's the relation between electric field and radial distance(?). Any showing of how to start this, or preferably the whole process in a somewhat understandable manor would be great, I will be checking the forums every couple minutes for conversation.
I'm also very unclear on del, I feel like that's the path to go but don't really understand how it works.
Thank you!
zSanityz said:
"Consider a charge density distribution in space given by [tex]\rho = \rho_0 e^{-r/a}[/tex], where [tex]\rho_0[/tex] and [tex]a[/tex] are constants. Using Gauss' Law, derive an expression for the electric
field as a function of radial distance, [tex]r[/tex]. Sketch the [tex]E[/tex]vs. [tex]r[/tex] graph.
For any radius [tex]r[/tex], the charge density outside that radius will contribute nothing to the electric field [tex]E[/tex], while the charge inside that radius will act as a point source with total charge Q equal to the integrated charge density over the volume inside that radius. These are direct results of Gauss' Law and the spherical symmetry of the problem.
Sorry about the delay, was having some connection issues. :X
And that all does sound very familiar, not sure I completely grasped it all though, if someone doesn't mind going through it or doing a step or two in the right direction (I learn best through example) that might be a bigger help for me personally, or just a simpler explanation.
I played around with it algebraically and brought in Coulomb's Law, E = 1/(4*[pi]*[epsilon]_0)*q/r^2, and [rho] = q/V, and got [rho] = (E*4*[pi]*[epsilon]_0*r^2)/V, and using volume of a circle = 4/3[pi]r^3, I was able to eliminate a lot, ending up with [rho] = (3*E*[epsilon]_0)/r.
And bringing it back to the original equation and isolating E, you get E = ([rho]_0*r)/(3*[epsilon]_0*e^(r/a)), meaning the graph would be dictated by r*e^(-r) ?
Let me know if any of this is wrong, I feel like I just butchered this problem by oversimplifying it. :X
Sorry, if the explanation is not clear. Sometimes these ideas are easier to express mathematically. Try the following.
Express Gauss's Law as follows:
[tex]\oint \vec D \cdot d\vec s = \int \rho dv=Q[/tex]
Consider a homogeneous medium with spherically symmetric charge density, and choose the surface of integration to be a sphere with radius R.
[tex]E_r = {{\int \rho dv}\over{4 \pi \epsilon R^2}}[/tex]
Notice that the field at any radius only depends on the charge density that is inside that radius. This is because the effects of the outside charges perfectly cancel. You could prove this yourself by doing the integration over exterior spherical shells of charge, but Gauss' Law already tells you this directly. The logic is a little subtle, but it depends on the fact that there is spherical symmetry in this case.
So now you have a formula for which you can substitute in the exact function for the charge density. Just integrate it out and you will have the function E(R), which is really the E(r) you are looking for.
Thank you! :D That's a much more understandable way to show it for me (math major).
I was looking over what you just explained and looking back at what I did the post beforehand and I think that's actually what I attempted to do, but I'm not 100% sure I did it all right, and is it okay to substitute in 4/3[pi]r^3 for V?
zSanityz said:
... is it okay to substitute in 4/3[pi]r^3 for V?
No, you have to do the integration out. If [tex]\rho[/tex] were constant then you could factor it out of the integral and use [tex]\rho V[/tex] with V being the volume of the chosen sphere. However, in this case [tex]\rho[/tex] is constant for changes in the [tex]\phi[/tex] and [tex]\theta[/tex] coordinates, but not the radial coordinate. Just plug into the formula for charge density and do the integral out slowly.
Ahh, alright, I'll try that! Thanks.
Though this is my worst subject in physics (though you can probably tell? :( ) and I'm REALLY bad at integrating in physics, great at it in math, but have trouble grasping it in physics for some reason. I also have to leave for a couple hours, so (if you don't mind!) could you leave the answer here so I could check my results after I get back and work through it.
And thanks for all the help on this, I hope my denseness in this area hasn't made it too difficult.
<3's
Well, that assumes that I have actually worked it out, which I have not.
It's quite simple, but should be worked out slowly to avoid mistakes.
It's well in your wheelhouse if you are a math major. :cool:
Lol, well like I said, I haven't quite grasped integrating in physics. Math is easy since variables there don't usually actually stand for anything. I have made some mistakes in the past in this area, and usually learn from them best by seeing the correct answer and being able to compare mine to it, finding where my mistake was (and I never make that mistake again), which is why I asked for yours. :p
But since you don't have it, I understand if you don't feel like working through it for me (especially if it's long), but if you are up for it (or anyone else on this forum who happens to check out this thread) I would be very appreciative if you would post the final result (and any major step if you feel like that as well -though I can usually figure those out when I see the final result)
Thanks! <3's
  • · Replies 26 ·
