Finding the mach number of an aircraft
  • Thread starter Thread starter jmm5872
    Aircraft Mach
The discussion revolves around calculating the Mach number of a supersonic aircraft based on the timing of sound from a rocket fired from the aircraft and the sonic boom experienced by an observer on the ground.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the geometry of the situation, with one attempting to use trigonometric functions to find the angle of the Mach cone and another questioning the validity of that approach. There are discussions about calculating distances using the speed of sound and the speed of the aircraft, as well as setting up a triangle to visualize the problem.
The conversation is ongoing, with participants providing feedback on each other's reasoning and calculations. Some guidance has been offered regarding the correct setup of the triangle and the relationships between the distances and speeds involved, but no consensus has been reached on the final approach to the solution.
Participants are working with time intervals related to sound travel and are trying to clarify the relationships between the distances and speeds of sound and the aircraft. There is a noted confusion about the correct interpretation of the triangle setup and the units involved in the calculations.
jmm5872
A supersonic aircraft is flying parallel to the ground. When the aircraft is directly overhead, an observer sees a rocket fired from the aircraft. 10.4 s later the observer hears the sonic boom, followed 3.37 s later by the sound of the rocket engine. What is the mach number of the aircraft?
I think I was too simple in my assumptions, but I used trig to find the half-angle of the mach cone. I used the adjacent side as 10.4, and the opposite side as 13.77, and took the inverse tan. I got an angle of 52.9375.
Then I used this to find the mach number by using this equation:
Mach # = 1/sin([tex]\theta[/tex])
=1/sin(52.9375) = 1.25317
Those 2 sides are not the 2 sides next to the 90 degree angle, so taking an inverse tan was wrong.
I calculated the distance from the point from where the sonic boom is first heard to the point where the rocket is released with pythagorars. (the other 2 sides are 13.77c and 10.4c where c is the speed of sound).
This distance is covered by the plane in 3.37s, so it's equal to 3.37v, where v is the speed of the plane.
I'm still a little confused by this. I am trying to set the triangle up and can't get past this diagram...I know you said it was wrong, but I can't picture the triangle you are describing.
I tried to attach a drawing I made, I hope it works
Your triangle is actually Ok, (and mine wasn't) but to get [itex]\tan{\phi}[/itex] you need to find the length of the sides in meters, and not in seconds.
The vertical distance is [itex]13.77 v_{sound}[/itex] and the horizontal distance is [itex]10.4 v_{plane}[/itex]
When you have an expression for [itex]\tan{\phi}[/itex], you can combine that with
[tex]\frac { v_{plane} } { v_{sound} } = \frac {1} {\sin{\phi}}[/tex]
10K
