Question about Joule-Thomson effect and Gulf blowout
  • Thread starter Thread starter marzolian
The discussion centers on the Joule-Thomson effect as it relates to the temperature of methane discharged from the BP blowout. Key assumptions include homogeneous flow of methane at an initial temperature of 350°F and a pressure drop from 16,000 psi to approximately 2200 psi at the wellhead. Participants highlight the complexities of accurately determining the outlet temperature due to variables such as gas composition and pressure conditions. The conclusion emphasizes that without precise upstream data, estimating the methane's temperature post-expansion remains speculative.
  • Understanding of the Joule-Thomson effect
  • Knowledge of thermodynamics, specifically isenthalpic processes
  • Familiarity with gas flow dynamics under high pressure
  • Basic concepts of hydrate formation in relation to temperature and pressure
  • Research the Joule-Thomson coefficient for methane at varying pressures
  • Study the thermodynamic properties of methane and its phase behavior
  • Learn about the impact of pressure drop on gas temperature in adiabatic expansions
  • Explore hydrate formation conditions in deep-sea environments
Engineers, thermodynamicists, and environmental scientists interested in gas behavior under high-pressure conditions, particularly in the context of offshore drilling and methane discharge scenarios.
marzolian
A friend who never studied engineering but is very curious sent me a blog entry, claiming that the methane being discharged from the BP blowout was cold enough to freeze seawater. I think someone is confusing water freezing with hydrate formation.
But I started wondering: What approach would you follow if you wanted to see how cold the methane would get, if it was flowing through an orifice and allowed to expand?
This does not represent a practical approach to solving that or any other real-life problem. But assume the following:
1. Homogeneous flow (methane only, no oil or other gases).
2. All pressure drop occurs at the wellhead. Ignore the resistance inside the well.
3. The pressure upstream of the restriction is the same as the downhole formation pressure, possibly 16,000 psi.
4. Initial downhole gas temperature is probably between 300 and 400 degrees F, assume 350 when it reaches the wellhead.
5. The methane flows adiabatically through the wellhead, and expands to the water pressure (approximately 2200 psi). (This is a significant assumption, because the pressure at the bottom of the riser / top of BOP stack is undoubtedly higher)
What would be the temperature of the methane, before it mixes with the seawater?
I know that Joule-Thomson is involved, but bear with me, it's been 25 years since I studied this subject and I haven't worked with it since then.
Can anyone give a back-of-the-envelope answer?
Steve Marzuola
Houston, Texas
I was wondering if it would get very cold myself. It's an isenthalpic expansion. But without knowing what the state is upstream and the exact composition (ie: how much methane and other gasses), you'd be guessing at what the outlet temperature would be.
http://www.eng-tips.com/viewthread.cfm?qid=272221&page=1
Don't forget that at 5000 foot depths you'd have a significant change in expansion rate as well. I officially deem this problem unsolvable by us mere mortals.
I will consult Google calculator.
10K
40K
10K
