Relativity of simultaneity (astronaut and simultaneous explosions.)
The discussion revolves around a physics problem involving an astronaut traveling at 0.17c who observes simultaneous explosions of nuclear devices while halfway between two planets. The astronaut calculates the time difference in the arrival of light from the explosions using the Lorentz transformation, arriving at a preliminary answer of approximately 20.7 minutes. However, participants suggest simplifying the approach by re-evaluating the problem from the astronaut's frame and considering a space-time diagram for clarity. The conversation highlights the complexities of relativity and the importance of correctly applying the relevant equations. Ultimately, the discussion emphasizes the need for clear reasoning in solving problems related to the relativity of simultaneity.
Gator93
An astronaut is space-traveling from planet X to planet Y at a speed of 0.17c. When he is precisely halfway between the planets, a distance of 1 light-hour from each, nuclear devices are detonated. The explosions are simultaneous in the astronaut's frame. What is the difference in time of arrival of the flashes from the explosions as observed by the astronaut?
v = 0.17c = 51000000 m/s
x = 2(1.079E12)
t' = 0 is simultaneous?
t = ?
t = (gamma)(t' + (vx'/c^2))
gamma = 1/(sqrt (1-B^2))
1/(sqrt (1-0.17^2))
1/sqrt(0.9711)
= 1.014770943
(1.014770943)(0 + (51000000*2.158505698E12)/(9E16)
= 20.687 min?
Now I'm not seeing how the units follow through on this without taking it from sec to min, but I've arrived at this answer a few other ways... namely multple equations and setting them equal to see when the first flash would encounter the ship and also when the second flash would catch up to the ship, and taking the difference.
So, I was giving this as a multiple choice problem.
A) 14 min B) 0 min C) 56 min D) 28 min
There is not an E) other... but wouldn't put it past him... then again I'm not confident I'm doing it correctly.
Welcome to PF!
Hi Gator93! Welcome to PF! :smile:
You're making this too complicated :redface:
first rewrite the question in the astronaut's frame …
what does it say? :smile:
You might try drawing a space-time diagram...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
