Calculating Thermal Expansion and Bending in a Pipe
A 10m, 16" diameter pipe carrying steam experiences differential thermal expansion due to a temperature difference of 220°C at the top and 110°C at the bottom, leading to potential bending. The temperature disparity arises from ineffective desuperheating, causing water to accumulate at the bottom and cool that section. To estimate the height the pipe would rise due to bending, one can calculate the increase in length at the top using the coefficient of thermal expansion for P11 steel. By fixing the endpoints and determining the arc radius based on the length increase, a first-order estimate of the rise can be obtained. Accurate calculations may require additional factors, but this method provides a basic approach to understanding the bending effect.
the4thworld
I was wondering if anyone could provide me with some info on a problem I am facing.
I have a pipe of 10m and 16" diameter. It has steam flowing through it, and due to inaccurate desuperheating we have a difference of temperatures at the bottom at top of the pipe.
Assuming we have a temperature of 220 deg C at the top of the pipe and 110 deg C at the bottom, we would have bending in the pipe due to differential expansion right?
The temperature difference is due to the desuperheating process not working as it should so there is water in the pipe that hasnt evaporated and thus falling down to the bottom of the pipe thus reducing temperature.
I wanted to know if there is a way to find out the height by which the pipe would rise due to bending.
The pipe is of P11 material( steel alloy)
thanks
Mike
I think the steam would mix top and bottom, reducing the top-bottom temperature difference with distance.
However, assuming that it does not. An approximate calculation is possible.
If you know the coefficient of expansion for the type of steel, you can calculate the increase in lengths of the top. Then consider the end points fixed and compute the radii of an arc with that length. That is a first order magnitude guess of how much it rises.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
