Convert octal to hex, w/out converting to Binary
  • Thread starter Thread starter dk702
    Binary Convert
The discussion focuses on converting octal numbers to hexadecimal without using binary, specifically the conversion of octal 173 to hex. The correct method involves repeated division by the hexadecimal base of 20 octal, leading to the correct answer of 7B hex. The initial approach mistakenly used decimal values, which resulted in incorrect calculations. The key takeaway is to interpret remainders correctly as single hexadecimal digits during the conversion process.
  • Understanding of octal and hexadecimal number systems
  • Familiarity with repeated division method for base conversion
  • Knowledge of how to interpret remainders in base conversions
  • Basic arithmetic operations with octal and hexadecimal numbers
  • Research the repeated division method for converting between different number bases
  • Learn about the properties of octal and hexadecimal systems
  • Study examples of base conversions without using binary
  • Explore common pitfalls in number base conversions and how to avoid them
Mathematicians, computer scientists, students learning number systems, and anyone interested in number base conversions without binary intermediary steps.
dk702
I have been trying to convert a from octal to hex and hex to octal without using binary. I believe the method is called repeated divison.
Example of problem I am trying to solve,
Convert 173 octal(123 dec) to hex
173 oct / 16 oct = 10 oct remainder 13 oct
10 oct / 16 oct = 0 oct remainder 10 oct
Reading up (1st division remainder is less sig. digit, and last is most sig.)
answer 1013 hex = 4115 dec. WRONG
answer should be 7B Hex
You can not mix octal and decimal numbers, and that "16" was decimal. Apply the repeated division on the decimal form of octal 173:
123=7*16 +11 which is 7B in hexadecimal form.
The conversion is possible also without using decimal form.
Working in the "hexadecimal word" 8=10/2
173 (oct) = 3+7*8+1*8*8 =3+7*10/2+1*10/2*10/2=
=3+(6*10/2+10/2) + 10/2*8=
=3+(3*10+8)+(4*10)=(3+4)*10+(3+8)=7*10 + B = 7B
(It is similar backwards. You know that the base of the hexadecimal numbers is 20 in your octal system. If you have 173(hex), for example, it is
3+7*20+1*20^2=3+(7*2)*10+4*100=
3+(10+6)*10+4*100=3+6*10+5*100=563.)
ehild
You can get this to work if you 1) Use the correct representation of the hexadecimal base (20 oct) and 2) Interpret remainders as single hexadecimal digits (which they must be).
173 oct / 20 oct = 7 oct remainder 13 oct (B hex)
7 oct / 20 oct = 0 oct remainder 7
answer 7B hex
11K
17K
10K
