2.45GHz RF microstrip Transmission Line design
For designing a 2.45GHz RF microstrip transmission line on an 8-layer PCB, there are key considerations regarding length and ground plane placement. The minimum length of the transmission line is not critical for efficient energy transmission to a matched load, but it becomes important when using open or short terminations for filtering, requiring adjustments based on the PCB's dielectric constant. The transmission line should ideally have its return path directly beneath it for optimal performance. Using striplines can enhance isolation due to their configuration between two ground planes, while microstrips may be more sensitive to environmental factors. Material properties and stack-up configurations also significantly impact the design, necessitating careful consideration of surface roughness and dielectric loss.
spid3rx
Hello all,
I'm now working on the 2.45GHz frequency transmission line layout on the PCB.
I would like to know whether there is a design guideline for the
1) minimum length of the transmission line. how do I know or calculate? I can calculate the width of the TL to get the 50ohm impedance based on which layer for the ground plane, but length? how?
2) the PCB is 8 layer type, is there a good rule to have for the TL ground to be on which layer? can I calculate the TL width on layer 2 ground and layer 4 ground ? mixture of both, and the TL width will be different.
thanks.
spid3rx
You can run the line on the surface above a ground plane =microstrip, with some stray radiation and sensitivity to the environment. https://en.wikipedia.org/wiki/Microstrip
You can place the line between two ground planes with vias to tie the planes = stripline, which has low radiation and well controlled impedance. https://en.wikipedia.org/wiki/Stripline
If the transmission line is being used to transmit energy efficiently to a matched load, the waveform and line length will not be important, there is no minimum length.
If the line is being used with an open or short termination to emulate C, L or a resonant filter, then the line length is critical and the signal needs to be a sinewave. The physical length will need to be sdjusted for the velocity factor due to PCB dielectric constant.
Likes tech99
It's definitely a good idea to have the return path of the transmission line right below it. I've seen coplanar waveguides (CPW) without a back plate although I cannot think of any good reason to use it if you're going to have 8 metal layers. Striplines as stated above will have its return paths above and below it, and this'll provide good isolation from traces on the other layers.
I have heard of vias causing problems at 3 GHz, but I'm not so sure about 2.45 GHz. You might want to pay attention to its geometry because it could create a mismatch between your two "matched" lines, which will ultimately make your load look mismatched.
What kind of material are you using? Surface roughness? Dielectric loss? Determining a stack-up is very challenging work. What else is going to be on your board?
Likes tech99
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
