Real Analysis (Rudin) exercise with inequalities
murmillo
Suppose k>2, x, y in R^k, |x-y| = d > 0, and r > 0.
Prove if 2r > d, there are infinitely many z in R^k such that
|z-x| = |z-y| = r
(In Principles of Mathematical Analysis, it is problem 16(a) on page 23.)
|ax| = |a||x|
|x-z| < or = |x-y| + |y-z|
|x+y| < or = |x| + |y|
I'm not quite sure how to tackle this proof. Here's the general outline I have:
- Show that there exists at least one z.
- Suppose there existed one and only one z. Is there a contradiction? Or, can I find z', a linear combination of z that also works and then from z' use the same rule to get z'', ad infinitum?
As you can see, I don't really know how to tackle "show there are infinitely many solutions" proofs.
One thought I had was, well, suppose z satisfies the necessary conditions.
Can I show that there exists c in R or d in R^k such that z' = cz + d also satisfies the necessary conditions?
But all I can get is |z' - y| = |z - y + d| < or = |z-y| + |d|
And |z' - y| has to = |z-y| = r, but that doesn't tell me anything.
Can someone give a hint or two to point me in the right direction? How should I tackle this problem?
Once you show that some z satisfies the equation, you can use the definition of the distance function in R^k to yield two quadratic equations in at least three unknowns. Expand with the binomial theorem and you cancel out the components of z and thus there are two linear equations in at k>2 unknowns, which has infinite solutions.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
