Formula for finding point on a line given distance along a line
  • Level: Undergrad
  • Thread starter Thread starter physicisTboB
    Formula Line Point
17 replies · 48K views · last reply
physicisTboB
So for a while i have been wondering if there was a way to find a point a certain distance along a linear function, so I decided that with my extreme pre-calc level of math that I would try and write an equation for it. long story short I would appreciate it if someone would take a look at the equation and try and figure out where I goofed up. The equation I came up with is:
c = sqrt((ox+a)^2+(m*(ox+a)+b-oy)^2)
where
c is the distance of the hypotenuse of a triangle with coords (ox,oy),(ox+a),(ox+a,f(ox+a))
a is the distance of the horizontal leg of the triangle
m, b are the slope and y-intercept of the line respectively
ox, oy are the original x and y coords on the line
px, py are the projected coords along the line
z is the distance along the line to the new projected point
deltax = (a*z)/c
where
deltax is the distance to the new point along the x-axis
px = deltax + ox
py = m(deltax+ox)+b
where
I hope this post isn't too incomprehensible seeing as I'm writing this at 12:30
Mathematics news on Phys.org
I have to admit you should have written it out at another time :-p
If you let your starting point be [tex](x_o,y_o)[/tex] on your line [tex]y=mx+b[/tex] and a distance d along this line to the new point [tex](x,y)[/tex] then you have equations:
[tex]d=\sqrt{(x-x_o)^2+(y-y_o)^2}[/tex] by the distance formula
[tex]m=\frac{y-y_o}{x-x_o}[/tex] for the gradient formula
Now all you need to do is solve these two equations simultaneously for x and y (m, d, yo, xo are all constants you know).
Note that from the second equation Mentallic gave you,
[tex](y-y_{0})=m(x-x_{0})[/tex]
Use this in your first equation to solve for x (you will get 2 solutions)
Essentially what you are doing is finding the intersections of the line [itex]y- y_0= m(x- x_0)[/itex] and the circle [itex](x-x_0)^2+ (y- y_0)^2= c^2[/itex].
Replacing y in the circle equation by [itex]y_0+ m(x- x_0)[/itex] gives the quadratic equation [itex](x- x_0)^2+ m^2(x- x_0)^2= c^2[/itex] which can be factored as [itex](x- x_0)^2(1+ m^2)= c^2[/itex] and so [itex](x- x_0)^2= c^2/(1+m^2)[/itex] and, finally,
[tex]x= x_0+ \frac{c}{\sqrt{1+m^2}}[/tex]
HallsofIvy said:
... and so [itex](x- x_0)^2= c^2/(1+m^2)[/itex] and, finally,
Being a little more pedantic, [tex]x=x_0\pm\frac{c}{\sqrt{1+m^2}}[/tex] and so
[tex]x=x_0+\frac{c}{\sqrt{1+m^2}} , x>x_0[/tex]
[tex]x=x_0-\frac{c}{\sqrt{1+m^2}} , x<x_0[/tex]
since c is the distance (a positive value) and [tex]\sqrt{1+m^2}[/tex] is also positive for all real m.
I don't know if I read the meaning of your constants and variables right, but it seems like the equation should be:
c = sqrt((a)^2+(m*(ox+a)+b-oy)^2)
instead of:
If all you're doing is using the Pythagorean theorum, and a is just the horizontal leg of the triangle.
PS- try Latex in your posts- all you have to do is go into advanced reply mode, and use the tags [tex]and[/tex] at the start and end of your equation. It makes things look pretty!
Whether what he did was correct or not so far, the fact is that he wants to find the point that is a certain distance from some other point along a straight line. This implies that he wants coordinates (x,y) in terms of d=distance, m=gradient, (xo,yo)=initial point. And I'm just not seeing that.
p.s. I gave the the OP's work another little glance and I'm looking away again. I'm simply afraid of delving into it...
px = deltax + ox
From what I can gather, a=deltax ? If they're the same then you shouldn't be introducing different names for the same thing, it just makes things more confusing.
And it would have been more appealing to read if you had used subscripts. the intial point (xo,yo) shouldn't be expressed as (ox,oy) since this suggests o times x and o times y. Then we wonder what the hell o is.
Chill, we were all in high/middle school once- I don't know of that many people who natively speak Latex. I only just learned how to use it myself a few weeks ago.
I think my correction may be on the right track- OP, would you mind clarifying what c and z are exactly? I think of c as just the hypotenuse/distance.
So here's the equation with wil3's correction (with latex =D)
c = [tex]\sqrt{((a)^2+(m*(x_o+a)+b-y_o)^2)}[/tex]
a, and c exist to establish legs of a triangle to get a ratio of line length to horizontal length,
and yes I found this using the Pythagorean theorem.
deltax is the horizontal distance from [tex]x_{o}[/tex] to [tex]p_{x}[/tex],
whereas a is the arbitrarily set value to use in the Pythagorean theorem.
And yes I suppose you could do this using a circle and whatnot.
wil3 said:
Chill
Actually I barely got any sleep last night because of this :wink:
Ok, but this is what you said in your OP:
Now your solution that you've shown us, without even checking to see if it's correct, is an equation to solve for c (the distance). This is because if you have c=something, then you plug in all the known values into the something then it spurts out your value of c, but you don't want that. You want to find a point (x,y) a distance c from an initial point (x0,y0).
No, c isn't the distance along the line, c is the hypotenuse of the triangle that is used to find the ratio of the x length to the distance along the line. Then using this ratio:
deltax the total change in x
c the hypotenuse of the triangle
a the horizontal leg of the triangle
z the distance to travel along the line
deltax/z = a/c
deltax = az/c
Oh I see what you mean now, but I still don't understand why you would need to do that. Why make a small right triangle with hypotenuse c and horizontal length x when the distance between your starting and ending point is a larger right triangle with hypotenuse z and horizontal length [itex]\Delta x[/itex]. Sure you can find a relationship between the small and larger triangles by similarity, but what's the point? You've just introduced more variables which aren't necessary and just make things more cumbersome.
Is the answer
[tex] \sqrt{((a)^2+(m*(x_o+a)+b-y_o)^2)}[/tex]
what you were looking for? Hallsofivy and I have pretty much given you the answer to your question (at least I think we did), it just depends on what your question actually was.
You said before, "c is the distance of the hypotenuse of a triangle with coords (ox,oy),(ox+a),(ox+a,f(ox+a))". If y= f(x) is the equation of the line, then that hypotenuse lies along the line and c is the distance along the line.
deltax/z = a/c
deltax = az/c
C does lie on the line, however it is not the total distance to the point.
Would you mind posting a picture or diagram with all the variables/constants labeled? This thread has proven to be a lot more interesting than I expected, but I know that at least I am a little bit confused as to the specific meaning of some of your variables. Thank you very much!
And what is the point of this? You could go even further and create multiple points with varying distances along the line, each not quite reaching the required distance. Why would you do this though? Sure they all have similar triangle properties, but,
[tex]\frac{\Delta x}{z} = \frac{a}{c}[/tex]
Doesn't tell us anything useful, since we're comparing our required sides of the triangle on the left side with a redundant triangle.
Would you mind please taking a look at my previous post and specifically this part,
Mentallic said:
Is the answer
Yeah, that's it I guess you've been right that I didn't have to do that first ratio with the a and c. I never really saw it like that, thanks.
