Circular motion - Force perpendicular to velocity does not change magnitude.
The discussion revolves around the concept of circular motion, specifically addressing the nature of forces acting perpendicular to the velocity vector and their impact on the magnitude and direction of velocity. Participants explore theoretical aspects, vector compositions, and implications of centripetal force in both uniform and non-uniform circular motion.
  • One participant asserts that in circular motion, the force perpendicular to the velocity vector changes only the direction of velocity, not its magnitude, and seeks clarification on their reasoning.
  • Another participant explains that if an object is moving at constant speed, the change in velocity points towards the center of rotation, while varying speed introduces additional accelerations.
  • A participant presents a diagram illustrating uniform circular motion as a polygon, emphasizing the role of centripetal impulses in changing direction without altering speed.
  • There is a discussion about whether the centripetal force influences both the direction and magnitude of velocity vectors, with one participant questioning the geometric conditions that would allow for equal magnitudes of resultant vectors.
  • Participants explore the properties of triangles formed by velocity vectors, with one asserting that certain triangles are isosceles, leading to equal magnitudes of specific vectors.
  • Another participant summarizes that the magnitude of velocity does not change due to the nature of the forces involved in circular motion, suggesting this is a general principle applicable to all circular motion.
  • One participant emphasizes that in circular motion, the force is always perpendicular to the direction of motion, causing only directional changes in velocity.
  • A later reply corrects a previous statement about triangle types, clarifying the geometric relationships involved.
Participants express differing views on the influence of centripetal force on velocity magnitude and direction, with some asserting that it does not change the magnitude while others question this assertion. The discussion remains unresolved regarding the implications of these forces in varying contexts of circular motion.
Some participants' arguments depend on specific assumptions about uniform versus non-uniform circular motion, and the discussion includes varying interpretations of vector relationships and geometric properties.
dreamLord
Hi, my first post here.
Right.
Spent the past hour searching all over for a clear explanation. In Circular Motion, or in general, the force perpendicular to the velocity vector changes only the direction and not the magnitude. Why is that so?
My reasoning against goes like this - please explain which of my statements is wrong.
Assuming velocity to be along x-axis, force acting along y-axis :
1/ Force produces acceleration.
2/ Acceleration will create a velocity along y-axis (initially v in y =0)
3/ Resultant of v along x(constant) and v along y(accelerated) will have different direction AND magnitude.
I've broken it into 3 statements, please tell me which part is wrong.
Much appreciated, thanks!
Science news on Phys.org
If the object is moving at constant speed, the change in velocity between any two points (the vector directions) points towards the center of rotation.
If there is varying speed, then there will be two accelerations, one towards the center of rotation and one in the direction of the velocity vector.
Can you be a little more clear? I didn't understand how to use that in this situation.
Luckily I had a diagram lying around that fits the bill.
In the diagram uniform circular motion is represented as motion along a 12-sided polygon. At points A, B, C etc the circumnavigating object receives an impulse towards the center of attraction.
The object travels from A to B and without a centripetal impulse it would proceed to point c in an equal interval of time. At point B the object receives precisely the impulse to make it travel the distance cC in an equal interval of time. The deflected velocity vector BC is the vector sum of Bc and cC.
The shorter the time intervals, the closer the approximation to the actual continuous motion.
I have a hunch that you are thinking in terms of vector composition of a tangential velocity vector with a radial velocity vector. But the polygon does not consist of tangential velocity vectors.
Erm, so the centripetal force IS influencing the velocity(in both M&D) isn't it? Isn't the velocity vector Cc the result of the force? And hence it will clearly influence the direction AND magnitude of vector Bc to BC. Or are BC and Bc the same in magnitude? If so - what geometric condition makes the resultant of 2 vectors equal to one of the vectors as in this case?
Yes, the triangle BcC is an [STRIKE]equilateral[/STRIKE] isosceles triangle. In other words, Bc and BC are equal in length.
Take a second circle, with identical diameter, that touches the first circle exactly at point B. Bc is equal in length to AB, therefore point c is a point on the second circle. It follows from symmetry that the triangle BcC is an [STRIKE]equilateral[/STRIKE] isosceles triangle.
So Cc is also equal to Bc and BC right?
Okay, let me get this straight. The centripetal force is actually creating a velocity vector (Cc) which is equal in magnitude to the original velocity vector Bc, and is at an angle of 60 degrees with Bc - which leads to the resultant also being equal in magnitude and at an angle of 60 degrees.
Is that right?
Is that right?
I made a language error in my previous message. I should have written 'isosceles triangle', but by mistake I wrote 'equilateral triangle'.
Ah okay. So basically the magnitude of velocity is not changing because the direction and magnitude of the velocity created by the centripetal force is such that an isosceles triangle is formed. And this is true for every circular motion. Is that right?
In circular motion the force applied is such that it is always perpendicular to the direction of motion. Its direction changes as velocity changes, so that it is always perpendicular to the velocity. At any moment the force only acts so as to cause a change in direction. Think about it like this. Take a circle of radius v(the tangential velocity). Consider this image in the folder: https://www.physicsforums.com/attachments/28169. Sorry, the writing isn't neat. It shows the force produces circular velocity change, but 0 velocity change in any given direction. Hope you understood. Here is a better one.View attachment circular motion.doc.
I think you meant uniform circular motion :)
Edit: The below is for the OP.
The treatment of this topic (circular motion - not just uniform) using vectors in Kleppner's "An Introduction to Mechanics" is excellent. It's the first chapter. You should really read that chapter. It certainly helped clear a lot of things for me about circular motion.
  • · Replies 37 ·
