How Do You Calculate the Tension in Cables Supporting a Suspended Loudspeaker?
  • Thread starter Thread starter Allura
    Cables Tension
To calculate the tension in the cables supporting a 26.0 kg loudspeaker, first determine the angle of the cables using the cosine function: cos(θ) = 1.9 m / 3.0 m. Once the angle is found, apply the formula T = (mg) / (2 sin(θ)), where m is the mass and g is the acceleration due to gravity. The tension in each cable can then be calculated by substituting the values into the equation. This approach ensures that the forces acting on the loudspeaker are balanced.
Allura
A 26.0 kg loudspeaker is suspended 1.9 m below the ceiling by two 3.0-m long cables that angle outward at equal angles. What is the tension (in N) in the cables? Assume that the local acceleration due to gravity is 9.80 m/s2.
I'm not sure how to approach this problem. I was thinking I would find the angle using cos -1 (1.9/3) and then using the angle to find T1?
mg/2 sin theta = T
What 1 angle = the other =.
Try that
Ok so I got 9.8x26kg/2 = 127.4 and do you mean sin-1(127.4)?
You need to find the angle of between the rope and the top of the building or w/e it's suspended on.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
