What is the maximum speed in a spring-mass system with low friction?
  • Thread starter Thread starter redalertkev
    Energy System
The maximum speed in a spring-mass system with low friction, spring stiffness of 220 N/m, and mass of 0.5 kg, released from an initial compression of 10 cm and an initial speed of 3 m/s, is calculated using energy conservation principles. The maximum speed achieved during the motion is determined to be 3.5 m/s. Additionally, with energy dissipation of 0.02 J per cycle, the average power input required to maintain steady oscillation is calculated to be 0.1 watts.
  • Understanding of Hooke's Law and spring constants
  • Basic principles of energy conservation in mechanical systems
  • Knowledge of angular frequency and oscillation frequency calculations
  • Familiarity with power calculations in oscillatory systems
  • Study the derivation of maximum speed in spring-mass systems
  • Learn about energy dissipation in oscillatory motion
  • Explore the relationship between angular frequency and oscillation frequency
  • Investigate advanced topics in harmonic motion and damping effects
Students studying physics, particularly those focusing on mechanics and oscillatory systems, as well as educators looking for examples of spring-mass dynamics and energy conservation principles.
redalertkev
A horizontal spring-mass system has low friction, spring stiffness 220 N/m, and mass 0.5 kg. The system is released with an initial compression of the spring of 10 cm and an initial speed of the mass of 3 m/s.
(b) What is the maximum speed during the motion?
(c) Now suppose that there is energy dissipation of 0.02 J per cycle of the spring-mass system. What is the average power input in watts required to maintain a steady oscillation?
(a) What is the maximum stretch during the motion?
I got .1745
I got .1745
I did not check this, but I will assume it is correct.
What is the angular frequency of the oscillation and hence what is the frequency?
