How Do You Correctly Add and Subtract Multiple Vectors?
  • Thread starter Thread starter k-rod AP 2010
    Vectors
The problem involves the addition and subtraction of multiple vectors, specifically vectorA, vectorD, and vectorB, with given magnitudes and angles. The original poster attempts to calculate the resultant vector from these operations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster describes their method of finding vector components and summing them to determine the resultant vector. They question whether their approach to treating the components of vectorB as negative during subtraction is correct.
Some participants confirm that the procedure appears correct, while others point out potential errors in the calculations of the vector components. There is acknowledgment of the original poster's uncertainty regarding their method.
The original poster mentions being in their first year of physics, indicating a learning context and possible challenges with the material. There is also a note about the original poster rushing through the calculations, which may have contributed to the errors identified by others.
k-rod AP 2010
vectorA: 6 @ 40o, vectorD: 2 @ 90o, vectorB: 10 @ 80o
i have to do this problem: vectorA + vector D - vectorB
i had found the components to these vectors in previous problems to be:
vectorA: x=4.01 y=4.46 vectorD: x=0 y=2 vectorB: x=9.85 y=1.74
i added the total x and total y for all the vectors:
total x: (4.01+0+ -9.85)=-5.84 total y:(4.46+2+ -1.74)=4.72
i made the components for the vectorB negative because they were being subtracted but i am not sure if this is the proper procedure
these are the resultant calculations based off of the x and y totals
resultant magnitude: root((-5.84)^2 + (4.72)^2)= 7.51m
resultant angle: arctan(4.72/-5.84)=-38.9o
Did i follow the proper procedure to add and subtract vectors in the same problem?
the procedure looks right to me... i haven't checked the calculations.
Your procedure is right, but some of your calculations are incorrect.
The components of vector A are off
The components of vector D look good
The components of vector B are reversed
Its my first year in physics so i am not the best at it but thanks for the confirmation. i thought it was right but i wasnt sure.
and zgozvrm, u were right about my numbers, i was doing the problem in a rush so i must have reversed them, my bad.
  • · Replies 38 ·
13K
