Is there any easier way to attack this problem?(perfectly elastic collision)
The discussion centers on solving a problem involving perfectly elastic collisions and the application of conservation of energy and momentum principles. The original poster seeks clarity on the derivation of the equation 1/2[(m_1)((v_i)_1)^2] = m_1gh, which relates kinetic and potential energy. Key calculations include determining the velocities of two spheres before and after the collision, as well as their maximum heights post-collision. An alternative approach is suggested, emphasizing starting from first principles to derive the necessary equations systematically. This method encourages a deeper understanding of the physics involved in the problem.
XwakeriderX
(see attachment)
The work the did gives the correct answer but i do not understand where a lot of that stuff came from! My first question about the work is how they derived 1/2[(m_1)((v_i)_1)^2] =m_1gh
Below is the solution
length of the string l =1.5 m
angle =25 degrees
height h_1 =h_2 =h =l(1-cosθ) =0.14 m
mass of the left side sphere m_1 =100 gm =0.1 kg
mass of the right side sphere m_2 =50 gm =0.05 kg
when left side ball is at height h (mass m_1) ,apply conservation of mechanical energy ,we get
velocity of the left side ball (v_i)_1,just before the collision (v_i)_1=sq.root (2gh) =1.657 m/s
after the collision:
b)
(v_f)_1 =[m_1-m_2/m_1+m_2](v_i)_1
substitute the given data in above equation we get,
velocity of the left side ball after the collision =(v_f)_1 =0.552 m/s
(v_f)_2 =[(2m_1)/m_1+m_2](v_i)_1
velocity of the right side ball after the collision =(v_f)_2 =2.21 m/s
c)
after the collision ,the height of m_1 is
( h_f)_1 =l(1-cosθ) =[[(v_f)_1]^2]/2g
(1-cosθ) =[[(v_f)_1]^2]/2gl
cosθ =1-[[(v_f)_1]^2]/2gl
maximum angle for left side ball ,θ =8.26 deg≈ 8.28 deg
after the collision ,the height of m_2 is
( h_f)_2 =[[(v_f)_2]^2]/2g
cosθ =1-[[(v_f)_2]^2]/2gl
maximum angle for right side ball ,θ =42.25 deg≈ 42.3 deg
How about instead of worrying about how someone else solved the problem, you start from first principles yourself to solve the problem? In sequence:
1. What is the energy of each ball just before they're released?
2. What is the energy of each ball just before they collide?
3. What is the momentum of each ball just before they collide?
4. What is the total momentum of the system before they collide? (express as a formula)
5. What is the total momentum of the system after they collide? (express as a formula)
6. What is the total energy of the system after they collide?
7. What is the momentum and energy of each ball just after they collide?
8. What is the energy of each ball when they are at the top of the swing after the collison?
By finding expressions for everything in order and applying the conservation laws, you will determine the angles for which you are asked.
Okay ill try that thanks!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
