An Atwood's Machine lab question?
  • Thread starter Thread starter pinky2468
    Lab Machine
The Atwood's Machine lab discussion highlights concerns regarding high percentage differences in experimental measurements, with ideal values being 10-15% compared to observed values of 40-50%. Key factors affecting accuracy include the precision of measurements, proper experimental setup, and correct calculations. Ensuring the pulley is frictionless, the string is taut, and that measurements are taken with appropriate instruments is crucial. Collaboration with lab partners and instructor guidance is recommended to identify and rectify potential errors.
  • Understanding of Atwood's Machine principles
  • Familiarity with experimental measurement techniques
  • Knowledge of percentage difference calculations
  • Ability to apply the acceleration theory equation
  • Review proper setup techniques for Atwood's Machine experiments
  • Learn about error analysis in physics experiments
  • Study the impact of friction on pulley systems
  • Practice calculating percentage differences with sample data
Students conducting physics experiments, particularly those involved in mechanics labs, educators teaching experimental methods, and anyone interested in improving measurement accuracy in laboratory settings.
pinky2468
I have a question...When you take times/measurements in lab, is the %difference supposed to be 40-50%? That seems like a lot to me! My lab partner took the measurements and I am suposed to do the calculations at home, but I am getting huge % difference for all but one of the 5 trials! We are using the acceleration theory equation versus the acceleration experiment. Can anyone help me with this so I don't totally mess up my lab because of my lab partner?
What exactly were you measuring and are you applying the theory correctly? How are you making the measurements? It's hard to say what kind of errors you will get without some detail.
Hello there,
Thank you for reaching out with your question about the Atwood's Machine lab. It is understandable that you are concerned about the large percentage differences in your measurements. Ideally, the percentage difference should not be more than 10-15%, so a 40-50% difference does seem quite high.
There could be a few reasons for this discrepancy. Firstly, it is important to ensure that your measurements are accurate and precise. Make sure that you are using the correct units and that your measurements are taken with the appropriate instruments. It is also important to take multiple readings and calculate the average to minimize errors.
Another factor to consider is the experimental setup. If the Atwood's Machine is not set up properly, it can affect the accuracy of your measurements. Make sure that the pulley is frictionless and the string is taut. Also, check that the masses are balanced on either side of the pulley.
Lastly, it is important to double-check your calculations and equations. Make sure that you are using the correct formula and inputting the correct values. If your lab partner took the measurements, it is possible that there could have been errors in recording the data.
I would suggest discussing this issue with your lab partner and going through the steps together to identify any potential sources of error. It is important to work together and communicate effectively to ensure accurate results. If you are still unsure, do not hesitate to ask your instructor for assistance.
I hope this helps and good luck with your lab!
