Theory type Question of Static Equilibrium
The discussion revolves around the concept of normal forces in static equilibrium, specifically in a scenario involving a sign attached to a pin joint and a spring. The question arises about why normal forces exist at the connection between the spring and the pin joint, as the original assumption was that normal forces occur only between rigid bodies. Clarification is provided that normal forces can indeed arise at contact points, including those involving springs connected to pin joints. The participants acknowledge that typical textbook representations may lead to misconceptions about where normal forces apply. Overall, understanding the behavior of springs in conjunction with pin joints is essential for solving the problem at hand.
AVQueen87
Hi everyone!
I just have a quick question about the theory behind a concept in statics.
Problem:
I was given a question that states that a sign is attached to a pin joint and also to a spring. The other end of the spring is attached to a spring joint as well. They hang there in static equilibrium and the spring is stretched from its initial position. I am to find the spring constant, k.
The picture looks like the one http://docs.google.com/viewer?a=v&q...JST4T&sig=AHIEtbR68GGRJvMjfoLJqjT_T1_ms1pCSg" in problem 41 (page 220) but the joints are instead pin joints.
Attempt:
I know that there will be normal forces between the pin joint and the sign. I also know how to find the tension force in the spring that is attached to the sign and
Question: This is more of a fundamental type thing I guess. My professor says that there are normal forces at both pin connections. Why is the connection between spring and the pin joint creating normal forces? I originally thought that normal forces would only occur between a rigid body and connection (like the pin connector and the sign). Any clarification on this theory would be greatly appreciated!
Thank you :smile:
Welcome to PF!
Hi AVQueen87! Welcome to PF! :smile:
At a contact point between two things, there will always be a https://www.physicsforums.com/library.php?do=view_item&itemid=73" , and if the contact is loose (eg no glue or screws) that will be a normal force if there is no friction.
The spring is presumably connected to the pin joint by a hook on the end of the spring …
why would there not be a normal force between the pin joint and the hook? :wink:
Mmm... I see now. So, for the majority of question in textbooks they just draw a spring/string/whatever-type-of-connector directly to the wall which makes it fixed, not like a pin connection. That's probably where I drew the (wrong) assumption that normal forces occur on rigid bodies - because I've never seen a scenario like this one!
Because this spring was connected to a pin joint, it will behave just like anybody connected to a pin joint... OK!
Thanks for the clarification, tiny-tim :) I can let my mind rest now, lol!
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
