How Much Waterproofing Do Everyday Electronics Really Have?
  • Thread starter Thread starter mugaliens
    Casio
Most everyday electronics, such as keyboards and calculators, lack significant waterproofing, making them vulnerable to spills and moisture. Devices like watches and automotive electronics typically have better moisture resistance due to their intended use. While some consumer electronics may offer drip resistance, they are not designed for prolonged exposure to water. Environmental factors, like temperature changes, can lead to moisture accumulation inside these devices. Proper care and storage can help mitigate moisture-related damage to electronics.
mugaliens
http://www.cnn.com/2011/TRAVEL/01/05/canada.flight.diverted/index.html"
The multi-function displays we used in the Air Force were at least water resistant, so either that was one heck of a coffee spill, or it somehow worked its way into the inner electronics!
How much consideration is given for waterproofing most user electronics? I swim with my watch all the time, but if I spill something in my $79 Logitech keyboard, it's toast. Same with my $11 Casio calculator.
Watches, automotive electronics, air conditioning electronics, and possibly items to be operated outside are going to be about the only items that have moisture resistance. All the cellphones, music devices, etc... may be drip resistant. However, heating and cooling through the course of a day will draw moist air in through the seams where it may condense and accumulate. Keeping these items inside or warm will drive off moisture.
Mike
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
