Zantra
- 794
- 3
I would like to get your opinions on this area. I am not a physicist, and so my knowledge of this area is almost nonexistant. Here's the link to some compiled information, below I'll give some excerpts. I'm purely interested in the scientific views on these theories, and weather they sound possible, or not possible.
http://www.seaspower.com/Outsidethebox-Loder.htm
the mid 1920's Townsend Brown [2] discovered that electric charge and gravitational mass are coupled. He found that when he charged a capacitor to a high voltage, it had a tendency to move toward its positive pole. This became known as the Biefeld-Brown effect.
The essence of electrogravitics thrust is the use of a very strong positive charge on one side of the vehicle and a negative on the other. The core of the motor is a condenser and the ability of the condenser to hold its charge (the K-number) is the yardstick of performance. With air as 1, current dielectrical materials can yield 6 and use of barium aluminate can raise this considerably, barium titanium oxide (a baked ceramic) can offer 6,000 and there is a promise of 30,000, which would be sufficient for supersonic speed."
Although general relativity has not been able to explain Brown’s electrogravitic observations, or any other antigravity phenomenon, the recent physics methodology of quantum electrodynamics (QED), appears to offer the theoretical framework to explain electrogravitic coupling.
The second aspect of these physics findings deals with the zero point or vacuum state energy shown by the Casimir effect, which predicts that two metal plates close together attract each other due to imbalance in the quantum fluctuations. The implications of this zero point or vacuum state energy are tremendous and are described in several papers by Puthoff [17] starting during the late 1980s.
The question that is being addressed is: what keeps the universe running? Or more specifically, where do electrons get their energy to keep spinning around atoms? As electrons change state they absorb or release energy, and where does it come from? The simplistic answer is that it is coming from the vacuum state. Puthoff [23] describes the process as follows: "I discovered that you can consider the electron as continually radiating away its energy as predicted by classical theory, but SIMULTANEOUSLY ABSORBING a COMPENSATING AMOUNT of energy from the ever-present sea of zero-point energy in which the atom is immersed. An equilibrium between these two processes leads to the correct values for the parameters that define the lowest energy, or ground-state orbit (see "Why atoms don't collapse," NEW SCIENTIST, July 1987). Thus there is a DYNAMIC EQUILIBRIUM in which the zero-point energy stabilizes the electron in a set ground-state orbit. It seems that the very stability of matter itself appears to depend on an underlying sea of electromagnetic zero-point energy."
Furthermore, it appears that it is the spinning of electrons that provides inertia and mass to atoms. These theories, linking electron spin, zero point energy, mass, and inertia have been presented in a number of recent papers, such as those by Haisch [24] and colleagues and provide us with a possible explanation of the Biefield-Brown effect. It appears that an intense voltage field creates an electromagnetic barrier that blocks the atomic structure of an atom from interacting with the zero point field. This slows down the electrons, reducing their gyroscopic effect, and thus reducing atomic mass and inertia, making them easier to move around.
We also have the next level of propulsion, it is called virtual field, which are called hydrodynamic waves..."
