Calculating Earth's Distance from the Sun in One Year
  • Thread starter Thread starter Miike012
    Sun The sun Year
The discussion centers on calculating the distance the Earth travels in a year, given a circular orbit with a radius of 92,500,000 miles. Participants clarify that this radius represents the distance from the Earth to the Sun, which is essential for determining the circumference of the Earth's orbit. The formula for circumference, C = 2πr, is highlighted as the method to calculate the total distance traveled in one year. There is some confusion regarding the terminology, with participants emphasizing that the radius in question is not related to the Earth's size but rather its orbital distance from the Sun. Ultimately, understanding the radius as the distance to the Sun is crucial for solving the problem accurately.
Miike012
Assuming that the Earth describes in one year a circle, of 92500000 mile radius, whose center is the sun, how many miles does the Earth travel in a year?
How does knowing the radius of the Earth help me with this problem? I don't need the radius of the Earth I need to know the distance from the Earth to the sun which will be the radius... then I can solve it...
Is this correct?
If I'm reading this correctly, for the sake of this problem, 92500000 miles is the distance between the sun and the earth. The Earth travels around the sun in a circular orbit, so 92500000 miles is the radius. How do you think we obtain the number of miles the Earth travels around the sun in a year?
Is this correct?
That radius is not the radius of the Earth. The orbit is circular, so that radius is the distance from the Earth to the Sun. So you just need to find the distance using the radius.
So based on the description, same formula as for a circle. You know the formula for circumference? Just note that the orbit of the Earth to the Sun might in fact be more like an ellipse.
The wording just through me off... I was thinking that the distance 92500000 was the dis. from Earth to sun, even though I read it as the radius of the earth..
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
