Energy Conversion Efficiency of EL Wire
EL wires, which utilize alternating current to illuminate phosphorescent materials, are recognized for their efficiency and low heat generation. The energy conversion efficiency, defined as the ratio of output radiative power to input electrical power, is essential for comparing EL wires with other lighting systems. The power draw and light output of EL wire are influenced by drive frequency and voltage, and it can be modeled as a capacitor with specific capacitance per foot. Variability in properties such as light intensity and current draw among different suppliers complicates performance assessments. Additionally, when considering battery applications, the efficiency of the inverter design significantly impacts overall power consumption and battery life.
Bararontok
As lighting decorations, EL wires that use an alternating current to make a phosphorous material radiate light are said to be very efficient and generate little heat. But what exactly is the energy conversion efficiency of such a device expressed as the ratio of output radiative power divided by input electrical power in percentage so that its performance can be compared with other lighting systems?
I've done some work with EL, but have never needed to do exactly what you're looking for.
Both the power draw and output intensity of a fixed amount of EL wire will depend on the drive frequency and voltage. Typically EL wire can be modeled as a capacitor with xxx capacitance per foot. You should be able to come up with an equation to model this.
I have found that the properties (light intensity, current draw, etc.) of a fixed length of EL wire varies greatly by supplier, so I'm not sure how that will play into your end goal.Edit:
If you're hoping to use this for a battery calculation or something like that, don't forget about the efficiency of the inverter design - that would be huge in terms of power consumption (battery life).
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
