Integrate f(x) = \frac{1}{(x-1)(x-2)} (1<x<2)
  • Thread starter Thread starter Kawakaze
    Integration
The discussion revolves around finding the indefinite integral of the function f(x) = 1/((x-1)(x-2)) within the interval (1, 2). Participants are exploring the integration techniques and the equivalency of different forms of the integral.
  • Mathematical reasoning, Assumption checking
  • Participants discuss the application of standard integral formulas and question the discrepancies between their results and those from computational tools like Wolfram Alpha and Mathcad. There is also a consideration of whether to treat the function as a compound function.
Some participants have provided clarifications regarding the equivalency of logarithmic forms and the importance of including absolute values in logarithmic expressions. There is ongoing exploration of the correct notation and assumptions regarding the constant of integration.
Participants are navigating the nuances of logarithmic identities and the implications of absolute values in the context of the integral. The discussion reflects a learning environment where assumptions about standard integral forms are being questioned and clarified.
Kawakaze
Determine indefinite integral of
[tex]f(x) = \frac{1}{(x-1)(x-2)}[/tex] (1 < x < 2)
Use standard integral
[tex]\frac{1}{(x - a)(x - b)} = \frac{1}{a - b}ln\frac{x - a}{x - b}[/tex]
This doesn't give me the same answer as wolfram alpha or mathcad
Should instead treat this as a compound function?
[tex]f(x) = \frac{1}{(x - 1)}\frac{1}{(x - 2)}[/tex]
I suspect that wolfram alpha and mathcad gave you answers in terms of inverse hyperbolic trig functions. If so, look it up on google, inverse hyperbolic trig functions are expressible in terms of logs.
Hi Gib
Thanks for the reply, unfortunately it may as well have been in russian. =)
My method using the standard integrals gives
[tex]-ln\frac{x - 1}{x - 2}[/tex]
Which I can't simplify any more really? Wolfram alpha and mathcad both give
[tex]ln(2 - x) - ln(x - 1)[/tex]
Your answers are eqivalent, using the log law: log(a/b) = log a - log b. Also, don't forget the absolute value sign your standard integrals should have.
Thanks Gib, that's good news, and I wasnt aware of the equivalency either =)
What do you mean absolute sign my standard integrals should have? I can't see an incorrect sign, please explain.
Lastly, should there be a +C at the end of this or not?
[itex]\int \frac{1}{x} dx = \log |x| + C[/itex], not just log x. Yes, there's always a + C at the end, its often omitted as it becomes assumed. Anyway, you need the |x| to ensure the term being log-ed is always positive.
So instead of [itex]- \log \left( \frac{x-1}{x-2} \right) + C[/itex], you should have had [itex]- \log \left| \frac{x-1}{x-2} \right| + C = - \log \left( \frac{x-1}{2-x} \right) + C[/itex], since 1 < x < 2 so [itex]|x-1| = x-1[/itex] and [itex]|x-2| = 2-x[/itex].
  • · Replies 105 ·
13K
