Height of Object Launched at 13.8 m/s
  • Thread starter Thread starter theredeemer
    Height
The discussion revolves around the height of an object launched from the ground at a speed of 13.8 m/s, described by the quadratic equation h(t) = -4.9t² + 13.8t. Participants explore the implications of this equation in the context of projectile motion.
  • Participants discuss setting the height equation equal to zero to determine when the object hits the ground. Some suggest rewriting the equation in vertex form to find the maximum height, while others propose using the concept of completing the square as a method to analyze the quadratic function.
The discussion includes various approaches to understanding the problem, with participants offering insights into the mathematical properties of the quadratic equation. There is no explicit consensus, but multiple interpretations and methods are being explored.
Some participants question the assumptions regarding the object's motion and the relevance of calculus concepts, indicating a range of familiarity with mathematical techniques.
theredeemer
An object is launched at 13.8 m/s from the ground. The equation for the object's height "h" at time "t" seconds after launch is: h(t) = -4.9t² + 13.8t, where h is in meters.
The object wouldn't be in the air anymore when it hits the ground, no? So what should you set h(t) equal to?
Assuming that you know nothing about calculus, recall that the vertex of a quadratic equation is the maximum or minimum point. So rewrite the equation in vertex form.
There are a couple of ways of achieving this:
  • The first way is to use your imagination. Notice that, when you launch the object from the ground, its speed is greatest, right? And then, as it flies off, the speed decreases. And when its speed is 0, it's also the time that object reaches its max height (before it starts to falls off).
    So, to find it's max height, we can calculate h(t0), where t0 is the time that its speed is 0.
  • The second way is to try to Complete the Square to find the maximum value for h(t). Have you studied how to Complete the Square?
    In case you haven't, I'll explain it briefly so you can get the idea. Completing the Square is the manipulation you do to change your expression into something like this:
    (a + b)2 + c, or c - (a + b)2
    The identity we should use here is the Square of Sum: (a + b)2 = a2 + 2ab + b2
    Example: Complete the Square for:
    • [tex]x ^ 2 + 3x + 1[/tex]
    • [tex]-x ^ 2 + 6x - 3[/tex]
    Problem 1: [tex]x ^ 2 + 3x + 1[/tex].
    First we'll split it so that it contains the first 2 terms a2 + 2ab, like this:
    [tex]x ^ 2 + 3x + 1 = x ^ 2 + 2.(x)\left(\frac{3}{2}\right) + 1[/tex]
    Then, we'll add, and subtract b2, note that, in this example: [tex]b = \frac{3}{2}[/tex] like this:
    [tex]... = x ^ 2 + 2.x\frac{3}{2} + 1 = x ^ 2 + 2.x\frac{3}{2} + \frac{9}{4} - \frac{9}{4} + 1 = \left(x ^ 2 + 2.x\frac{3}{2} + \frac{9}{4}\right) - \frac{5}{4}[/tex]
    [tex]= \left( x + \frac{3}{2} \right) ^ 2 - \frac{5}{4}[/tex]
    Problem 2: [tex]-x ^ 2 + 6x - 3[/tex].
    It's the same, except that we have a little minus sign "-", in front of x2, right? So we can factor -1 out, like this, and do the same as what we've done above:
    [tex]-x ^ 2 + 6x - 3 = -(x ^ 2 - 6x + 3) = - (x ^ 2 + 2.x.3 + 3) = - (x ^ 2 + 2.x.3 + 9 - 9 + 3)[/tex]
    [tex]= - [(x ^ 2 + 2.x.3 + 9) - 6] = -[(x + 3) ^ 2 - 6] = 6 - (x + 3) ^ 2[/tex]
    After Completing the Square for h(t), you can find its maximum value by noting that: [tex]\alpha ^ 2 \ge 0 , \forall \alpha \in \mathbb{R}[/tex]
Let's see if you can tackle this problem on your own. :)
Moderator's note:
Since this thread is a duplicate, I am closing it.
  • · Replies 21 ·
  • · Replies 21 ·
