Calculating Charge in a 9V, 12W Radio
  • Thread starter Thread starter aaronmilk3
    Charge Radio
To calculate the charge passing through a 9V, 12W radio over 1.33 hours, the correct approach involves determining the current using the formula P = IV, leading to I = P/V, which gives 1.33A. The total time in seconds is 4,788 seconds. The charge can then be calculated using Q = It, resulting in Q = 1.33A * 4,788s, which equals approximately 6,367 coulombs. The initial miscalculations stemmed from incorrect resistance and power equations. Ultimately, the correct charge calculation resolves the confusion.
aaronmilk3
A person runs a 9.0 V, 12.0 W radio for 1.33 hours. How many coulombs of charge pass through the wires in the radio during this time?
I used Power= pot difference/Resistance = 9v/120w=7.5e-2
I=current
Then I used I²=P/R= 120v/7.5e-2 = 1.6e3
I=40A
1.33h*60mins*60secs = 4.788e3
Q=Charge
Then Q=It = (40A)(4.788e3 secs) = 1.92e5 but this is not the right answer.
Any help would be great. Thanks!
I made a mistake with the first equations it is P=pot diff²/R => R= pot diff²/R so I ended up recalculating and I got 6.384x10^4 but it is still not right.
Never mind I figured out
