New Reply
Please check my work.. energy required to raise temp by 10deg..thanks
Share Thread Thread Tools
Feb20-11, 05:14 PM   #1
You want to heat 1 L of water by 10 ºC, and so you heat it with a mechanical egg beater that is powered by a 1 kg mass on a rope over a pulley. How far does the mass have to descend to supply enough work for heating the water?
2. Relevant equations
|work| = mg(x_f - x_0)
C_P (liquid water) = 75.3JK^-1mol^1
3. The attempt at a solution
I first asked myself how much energy does it take to increase the temp of 1kg of water by 10degC.
Heat capacity of water (above) is the energy required to heat 1 mol of water by 1deg.
So I first determined how many moles of water i have:
1L = 1kg = 1000g * (1mol/18.01g) = 55.5mol of liquid water
Therefore 55.5mol *75.3JK^-1mol^1 = 4179.15J/K * 10K = 417915.0J
So it requires 417915.0J to raise the temp of 1kg water by 10degC.
This is the work required also because work is also in joules, --energy.
Then i used the formula for mechanical work to determine the value for delta x.
417915.0J(1kJ/10000J) = 1kg(9.81m/s/s)(x_f) (i got ride of x_0 because I set scale so that x_0 = 0)
x_f = 42.6m
So the mass has to descend through 42.6m in order to heat 1kg of liquid water by 10 degC.
Is this correct or if not please help..thanks alot. I also have some other questions about the problem but i dont want to ask until i know if my answer is correct...thank you again
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
New Reply
Thread Tools
Similar Threads for: Please check my work.. energy required to raise temp by 10deg..thanks
Thread Forum Replies
What is the energy/work required to turn something? General Physics 47
energy problems/work check Introductory Physics Homework 2
Energy Calculations please check work (thanks) Introductory Physics Homework 1
Energy work calculations (please check over) Introductory Physics Homework 1
Energy required to raise temperature. Classical Physics 13
