How do I calculate scale weight for testing a scale glider?
To calculate the scale weight for a 1:4 scale model of a glider, the weight should be determined based on the cube of the scale factor, which is 64 times lighter than the full-scale model. If the full-scale glider weighs 100 kg, the model should weigh approximately 1.5625 kg. While the scale speed can initially be thought to reduce to 1/4, to accurately replicate aerodynamics, the speed must actually be increased by a factor of 4. Understanding the Reynolds number is also crucial for ensuring proper aerodynamic behavior in the model. Accurate calculations are essential for effective testing of the glide ratio.
Moomba
Hello all - I'm new to the forum - I hope some kind person can help with a question of calculating scale weight in a scale model of a glider.
I want to test the glide ratio of a glider design by making a 1:4 scale model and thowing it from a certain height at a certain speed and measuring how far the model glides.
Suppose the design has 10m wingspan and the model has 2.5m ws.
The question is: if the full scale design weighs, say, 100kg (including pilot) what should the 1:4 scale model weigh?
(And, I'm supposing that the scale speed should just be reduced to 1/4 ?)
Typically, weight, being proportional to volume scales as the cube of length. If typical lengths on the actually glider are 4 times the model lengths, then its weight will be 4^3= 64 times the model's weight. If the full scale is 100 kg,the model should weigh 100/64= 1.5625 kg.
Yes, speed= length/time and, since time is not scaled, will scale the same way as length.
Actually to properly reproduce the aerodynamics the speed would have to be increased by a factor of 4. Are you familiar with the Reynolds number?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
