New Reply
Energy Conservation & Potential Energy.. Spring/Friction Problem
Share Thread Thread Tools
Mar6-11, 01:31 PM   #1
A 0.80-kg block is held in place against the spring by a 67-N horizontal external force. The external force is removed, and the block is projected with a velocity v1 = 1.2 m/s upon separation from the spring. The block descends a ramp and has a velocity v2 = 1.9 m/s at the bottom. The track is frictionless between points A and B. The block enters a rough section at B, extending to E. The coefficient of kinetic friction is 0.39. The velocity of the block is v3 = 1.4 m/s at C. The block moves on to D, where it stops. In Fig. 7.4, the force constant of the spring is..
2. Relevant equations
K1 +U1 +W other = K2+ U2.. ect .. U2=0.5kx^2 .. K1=(0.5)mv^2
3. The attempt at a solution
I've tries solving the problem with the equation above but I really just don't know where to start especially since there are no units of distance given.. Can someone lead me in the right direction please?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar6-11, 02:08 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Help1212!
(try using the X2 and X2 icons just above the Reply box )
I assume you can find kx and kx2/2 ?
ok, then k = … ?
Mar6-11, 02:57 PM   #3
euhh... i'm still a little confused..how do i find k if I don't know x?
Mar6-11, 03:02 PM   #4
Recognitions:
x is twice kx2/2 divided by kx
Mar6-11, 03:31 PM   #5
hmm. well when I move around the equation i get k=2[0.5(mv22)/x2
from the assumption that K1 + U1 = K2 + U2
Am i going in the right direction??
Mar6-11, 03:48 PM   #6
Recognitions:
can you find kx and kx2/2 ?
if so, what are they?
New Reply
Thread Tools
Similar Threads for: Energy Conservation & Potential Energy.. Spring/Friction Problem
Thread Forum Replies
Problem involving spring, friction, circular motion, work, and conservation of energy Introductory Physics Homework 1
Energy conservation (potential, kinetic, spring) Introductory Physics Homework 9
Spring (conservation energy) with friction Introductory Physics Homework 14
Conservation of energy involving spring and friction Introductory Physics Homework 1
