New Reply
Japan Earthquake: nuclear plants
Share Thread
May15-11, 02:20 PM   #7328
Thank you. And it's actually funny that the article is from March 18 and very well makes my point: the scale changes.
Being on the brink then meant that cooling was imperative since "otherwise, a meltdown of the core could occur or, respectively, continue in the reactors."
"Die Kühlung der Reaktoren und der Abklingbecken der Reaktoren 1 bis 4 ist entscheidend. In den Reaktoren könnte sonst eine Kernschmelze einsetzen beziehungsweise weiterlaufen."
For Unit 1, we're past that and on a new brink, I suppose.
May15-11, 02:32 PM   #7329
Salad ideas:
The corium is very quickly a firm skin.
At this time, borated water is not able to do its work.
The gescmolzenen pellets in the corium are critical and can tear the skin.
Borated water penetrates and prevents the critical situation.
Neutrons are absorbed. The skin will close again and the result is again criticality. The skin tears open again and borated water penetrates. Neutrons are absorbed and prevented the criticality.
The theater goes on until all the fission products are exhausted. The corium remains hot until the fission products are exhausted.
So far so good.
As long as not burst the vessels, one can talk from a funny cat and mouse game.
May15-11, 02:33 PM   #7330
Chubu Electric Power Co. said Sunday that cooling system trouble delayed the 'cold shutdown' of the No. 5 reactor at its Hamaoka power plant in Shizuoka Prefecture for about two hours earlier in the day, while ruling out any external release of radioactive substances.
http://english.kyodonews.jp/news/2011/05/91196.html
Has it reached cold shutdown yet ?
(EDIT : yes it has ... http://search.japantimes.co.jp/cgi-b...0110516a5.html )
The Nagoya-based firm said the problem in the reactor's cooling system was found Saturday evening after a gauge indicated that around 400 tons of seawater had flowed into the condenser at around 4:30 p.m., most likely because of a piping problem.
The water also found its way into the reactor, making it necessary to desalinate it, the company said.
That's kinda what you see ... One report speaks of 2 hours trouble on a Sunday , the other says the problem had been found Saturday starting at 4:30 p.m. .......Tsk Tsk
May15-11, 02:42 PM   #7331
I forgot to mention:
While the skin breaks and water comes with the liquid part of the corium in connection arises suddenly steam. This steam can be derived as barrier-free. Otherwise there is a steam explosion. In addition, the highly radioactive steam.
May15-11, 02:44 PM   #7332
Quote by etudiant View Post
You highlight vividly how the spin is corrupting the message. Then Japan's government wonders about the emergence of 'rumors' in other countries.
Afaik, the likelihood of another major blast is much smaller now, although reactor 3 could still experience a steam explosion if/when the core remains believed to be still in the reactor pressure vessel melt through and fall into the now flooded dry well. The only question is how much more damage is likely to come, hopefully relatively little, as the bulk of the volatile radioactives have already been boiled off.
Beyond that small comfort, the situation will remain as is for the rest of the year and perhaps much longer,
a shattered site littered with intensely radioactive debris, flooded with a lake of water 100x300x3 meters deep, so radioactive that it can only be approached briefly. That will make cleaning up the spent fuel pools a very long term proposition, so airborne emissions are also likely to continue for a long while.
If the readings from sewage plants near Tokyo and beyond are correct, the accident has already contaminated the larger part of Honshu to the point that the government will have to raise the allowable radiation contamination standards. Seafood and seaweed products are likely at risk for a very long time.
The spin and hence the correct/best interpretation of the scientific data (by you guys, of course, not me) is what's so important.
It's maybe just natural that a progression from bad to even worse and yet worse is difficult to accurately put into perspective, but at the same time I'm concerned about deliberate minimization by the plant operator, government, and mass media and the consequences for the affected population. For those of us Europeans and Russians who are old enough to remember the Chernobyl aftermath, very similar to the Fukushima situation, the info for the public started with "don't worry about it," went to "well, it's bad but not dangerous," to "yeah, it's worse than thought, but not deadly." (obviously paraphrased)
If the risk from Units 1-3, at a minimum, is the continued contamination of ground- and seawater through radioactive water leakage, I hope every layperson makes a decent effort to understand what's going on and what the consequences for him/her may be.
Many thanks to you knowledgeable folks and experts who put so much effort into collecting and interpreting the scientific data as it becomes available. Even if we laypersons may not comprehend the highly technical stuff, we at least don't have to rely on the spin in press releases and mass media reports because you instead provide us with -at a minimum- educated guesses what's going on and we can then guess what it all means for each individual in his/her respective geographic location.
May15-11, 02:46 PM   #7333
Recognitions:
Gold Membership Gold Member
Quote by GJBRKS View Post
Wow! That is a serious screw up.
To have sea water enter the reactor means that they really gummed up the shutdown operations.
Under normal circumstances, heads would roll. Now, it's just a problem in a plant that is dead anyways.
Still does not speak well for the competence of the operation.
May15-11, 02:51 PM   #7334
This site is complaining that Chubu delayed 20 hours before making an announcement about the seawater: http://criticality.org/2011/05/hamao...rway-problems/
Based on Chubu Electric’s 20 hour delayed announcement on the morning of May 15th, they confirmed that seawater has been detected in the water circulation system.
Chubu Electric’s excuse for the 20 hour delay
Quoting NHK news this is Chubu Electric’s response when asked about the 20 hour delay in releasing information to the public about the cooling water contamination problems,
“There has not been environmental releases of radiation, because Chubu Electric is not legally subjected to reporting the situation to the government, we did not make any immediate announcement when it occured.” Chubu Electric, May 15th press annoucement.
May15-11, 02:52 PM   #7335
Quote by SteveElbows View Post
There are only a few images from the period after 3 blew but before 4 went up.
I dont think the resolution is high enough to be 100% sure, but it looks to me like there was already debris fallen onto the pipe in the place where it is later shown to be broken. And I think its always been a pretty likely bet that it was falling walls of reactor 3 that caused the damage.
Yes, in your pictures it already looks like the broken pipe *after* Unit 4 explosion:
May15-11, 02:57 PM   #7336
Recognitions:
Quote by mscharisma View Post
It's maybe just natural that a progression from bad to even worse and yet worse is difficult to accurately put into perspective, but at the same time I'm concerned about deliberate minimization by the plant operator, government, and mass media and the consequences for the affected population. For those of us Europeans and Russians who are old enough to remember, very similar to the Fukushima situation, the info for the public started with "don't worry about it," went to "well, it's bad but not dangerous," to "yeah, it's worse than thought, but not deadly." (obviously paraphrased)
Many thanks to you knowledgeable folks and experts who put so much effort into collecting and interpreting the scientific data as it becomes available. Even if we laypersons may not comprehend the highly technical stuff, we at least don't have to rely on the spin in press releases and mass media reports because you instead provide us with -at a minimum- educated guesses what's going on and we can then guess what it all means for each individual in his/her respective geographic locations.
There is no doubt that the leadership , both corporate as well as national, is treading a fine line, trying to minimize concern without doing real violence to the truth. So any public statement should be read in the context that it aims to reassure first, even before it informs.
The problem this creates, at least imo, is that it does not adequately take into account the extra vulnerabilities of children, who play in the dirt a lot and who are more susceptible to contamination damage.
Of course, the damage done to everybody, children included, from a panic or mass evacuation would be even worse, so the same logic applies, reassure and tell the unavoidable minimum. Not an easy balancing act.
May15-11, 03:08 PM   #7337
Sea water in Hamaoka cooling system
If sea water is detected in the cooling loop of the reactor, leads me to believe that there is a problem in the heat exchanger of the cooling system. In the closed loop you have reactor water which exchanges its heat to the sea water. If there is a crack in the heat exchanger sea water can be sucked into the reactor circuit, either due to Bernoulli effect at high flow rates or the system was at under pressure as steam condensed to water at the cooling stage and fresh water was not replenished fast enough.
May15-11, 03:23 PM   #7338
Quote by AntonL View Post
Would such a system have 3 cooling loops , another heat exchange at the reactor ?
If not then I guess contamination of reactor water into the environment can not be ruled out.
(I'm not saying it would be radioactive , just that it would have breached containment)
May15-11, 03:25 PM   #7339
I dont think they had stated that the Hamaoka closure was to be permanent. I think it was supposed to remain shut whilst they came up with new measures against things like tsunami. Of course its possible that it would never reopen if such measures could not be completed or the politics remained very difficult, but thats not how they wanted to present the story at this time.
May15-11, 03:52 PM   #7340
A PDF about unit 1 shows two floor plans. I don't know if they show anything not known here yet:
http://www.meti.go.jp/press/2011/05/...10515001-5.pdf
(I believe it's about the staircase in the north-west where they have seen water accumulating).
May15-11, 04:22 PM   #7341
Tepco have been reading this forum for ideas, I postulated this a month ago
and again later
That was just too easy,do another one cos I can't quite believe Tepco are that dumb. Then again on reflection ,no need.
May15-11, 04:25 PM   #7342
Quote by clancy688 View Post
That's odd.
3/11 - 14:46: Tohoku earthquake
3/11 - 15:41: Tsunami impact
3/11 - 16:36: Battery failure in Unit 1
3/11 - 17:07: Isolation Condenser active in Unit 1
3/12 - 05:30: Unit 1 primary containment pressure 820 kPa
3/12 - 06:46: +16 hours
3/12 - 10:17: Venting of Unit 1
3/12 - 11:20: Fuel rods 90 cm exposed in Unit 1
3/12 - 15:36: Explosion of Unit 1
The meltdown occured before venting and before the fuel rods got exposed?
If they say now truth, the only explanation is see is that... they were lying before! Well, we can understand it, why panicking people recognizing the reactor just melted in the first 16 hours?
Is their new assessment not far from the old original document assessing what would happen in a timely manner in case of severe accident in a BWR mark I reactor?
By the way, have these studes already been posted here?
1) VERY INTERESTING STUFF IN IT, details and schematics including failure modes
THE IMPACT OF BWR MK I PRIMARY CONTAINMENT FAILURE
DYNAMICS ON SECONDARY CONTAINMENT INTEGRITY
http://www.osti.gov/bridge/servlets/...Hq/5835351.pdf
2) IDENTIFICATION AND ASSESSMENT OF BWR IN-VESSEL
SEVERE ACCIDENT MITIGATION STRATEGIES
http://www.iaea.org/inis/collection/...2/24072657.pdf
May15-11, 04:37 PM   #7343
Quote by PietKuip View Post
That was when all the industry experts told us in TV that such a thing was impossible.
Yep, i remember well also...
It will be very interesting to re-read this thread from scratch after some time.
May15-11, 04:40 PM   #7344
Quote by ~kujala~ View Post
Nice work, Anton!
(BTW: I remember there were some counterarguments against your theory. Now that TEPCO has adopted your theory is there any more validity in these counterarguments? TEPCO engineers must know their plants so their evaluations about possible theories have a certain level of assertiveness, which the outsiders lack.)
i still don't buy that. there were more than 24 hours between the explosions of #3 and #4...
and we have this information ('tepco says...') only second hand. the same quality of information as we had before for a contradictory explanation (explosion in #4 blowed away a gate and reflooded the SFP).
let's wait and see ;-)
something else:
as i am not able to see the 'live feed', can anyone who can see it confirm, that everything looks normal?
the webcam shows something, that might be smoke: http://pointscope01.jp/data/f1np/f1n...0516060032.jpg (its the same pic, that the webcam shows right now)
New Reply
Tags
japan, nuclear
Similar discussions for: Japan Earthquake: nuclear plants
Thread Forum Replies
8.9 earthquake in Japan: tsunami warnings Current Events 671
New Nuclear Plants Nuclear Engineering 9
Gen IV Nuclear Plants Nuclear Engineering 10
New Nuclear Plants Nuclear Engineering 14
Astronomer Predicts Major Earthquake for Japan General Discussion 65
