Can you weaken a magnetic field with the peresnce of ferris materials?
The discussion centers on the interaction between a magnetic rod and ferromagnetic materials, specifically steel. When a magnetic rod with a diameter of 1 inch and a length of 18 inches is attached to steel at both ends, the magnetic pull at the southern end does not diminish in the air, despite the presence of steel. The concept of magnetic susceptibility indicates that while the magnetic field (B field) inside the steel may weaken, the external magnetic field remains unchanged, maintaining its original strength of 20 pounds at both poles.
  • Understanding of magnetic fields and their properties
  • Knowledge of magnetic susceptibility and its effects
  • Familiarity with ferromagnetic materials, specifically steel
  • Basic principles of magnetism, including north and south poles
  • Research the concept of magnetic susceptibility in detail
  • Explore the effects of ferromagnetic materials on magnetic fields
  • Study the principles of magnetism, focusing on field strength and pole interactions
  • Investigate practical applications of magnetic fields in engineering and technology
Physics students, materials scientists, engineers, and anyone interested in the practical applications of magnetism and magnetic materials.
Gabe21
suppose you had a magnetic rod with a diameter of 1" and around 18 inches long, and the north and south poles are oriented at the ends of the rod. if you stuck the north end of the magnet to a piece of steel would it effect the magnetic pull at the southern end?
if the north and south poles had an attraction force of 20 pounds when independently stuck to steel, if steel was stuck to both ends would it only have an attraction force of ten pounds at the poles?
well you could look at Magnetic susceptibility of the material . Inside the material the B field would be weaker but out in air the B field will be the same as if the material wasn't even there.
  • · Replies 17 ·
10K
13K
