How Do You Calculate Properties of a Transverse Wave?
In summary, the amplitude of the wave is 0.05, the wavelength is 4.19x-1260t, the wave is travelling at a maximum tranverse velocity of Vmax= 2∏A/λ, and the period is the reciprocal of the wavelength.
KatieKT
A transverse wave is described by the expression y= 0.05cos(4.19x-1260t). You may assume all measurements are in the correct SI units.
A) What is the amplitude of this wave?
B) What is the wavelength of this wave?
C) How fast is the wave travelling?
D) What is the maximum tranverse velocity of the wave?Relevant equations: y= a sin (b(x-c)) +d
Lamda= velocity/frequency
Velocity= delta x/ time
A) the amplitude is 0.05 as "a" in the formula is always amplitude.
I am having trouble figuring out the last three questions but. How you do figure out the wavelength? Do you have to draw the wave on a quadrant graph and get the information off that?
Welcome to PF!
hi KatieKT! Welcome to PF! :smile:
(have a lambda: λ and a delta: ∆ :wink:)
We measure the wavelength at a fixed time
for fixed t, how much do we change x for y to be repeated?​
(And we measure the speed at a fixed height
for fixed y, what is the ratio of x to t for y to stay constant?)​
Yeah so in y=a cos(bx + c) + d, a is amplitude and b would be the one that effects the period/wavelength. So is it 4.19m's long? Usually I thought that along the bottom of the graph it's like 45, 90, etc for thesse types of graphs but I don't think that's right.
Think about what the wavelength means. 4.19x-1260t is the angle being fed into the cosine function, so it should advance by 2pi (representing one cycle) every time x advances by lambda. If we hold t constant, what should lambda be so that this is true? You can use the same reasoning to find the period. Speed would then be wavelength/period.
It's like 45,90,etc. if you plot sine or cosine with the angle on the x axis. In this case, bc+x is the angle being fed into the cosine function. You can definitely plot y=acos(bx+c)+d as a function of this angle, although for this question, I don't see why you would.
PS. Anyways, try to use y=acos(wx-kt). It's much more common and intuitive than y=acos(bx+c)+d, since a, w, and k both have well-defined meanings.
Ok so I've worked out λ to be 1.49m through 2∏/b. Then the frequency by 1/1.49 to get 0.23Hz. However to get the velocity I was told to use v= -Vmax sin(-1260t) and the formula for the maximum transverse velocity was Vmax= 2∏A/λ. Is 2∏A/λ the correct formula to use however? I know for maximum velocity it is, but is it also the formula for maximum transverse velocity?
FAQ: How Do You Calculate Properties of a Transverse Wave?
What is a transverse wave?
A transverse wave is a type of wave that moves perpendicular to the direction of the wave's energy transfer. This means that the particles of the medium are displaced in a direction that is perpendicular to the direction of the wave's propagation.
How do you calculate the wavelength of a transverse wave?
The wavelength of a transverse wave can be calculated by dividing the speed of the wave by its frequency. The formula is: wavelength (λ) = speed of the wave (v) / frequency (f).
What is the relationship between frequency and wavelength in a transverse wave?
In a transverse wave, frequency and wavelength are inversely proportional. This means that as the frequency increases, the wavelength decreases, and vice versa. This relationship is described by the formula: frequency (f) = speed of the wave (v) / wavelength (λ).
How do you calculate the period of a transverse wave?
The period of a transverse wave can be calculated by dividing the wavelength by the wave's speed. The formula is: period (T) = wavelength (λ) / speed of the wave (v). Alternatively, the period can also be calculated by taking the inverse of the frequency.
What is the speed of a transverse wave?
The speed of a transverse wave is the distance the wave travels per unit time. It can be calculated by multiplying the wavelength by the frequency. The formula is: speed of the wave (v) = wavelength (λ) x frequency (f).
