Can Pulsing White Light Reveal Its Component Colors?
  • Thread starter Thread starter cragar
    Light White light
Pulsing white light does not reveal its component colors unless a prism or similar diffracting structure is used. Optical illusions can create the perception of color from pulsating white light, such as when viewing a rotating disc with alternating black and white stripes, which can trick the eye into seeing bands of color. This effect is subtle and varies significantly among individuals, likely due to differences in how color receptors in the eye respond. While the illusion can be intriguing, it does not serve as a method for true color synthesis like that required for color television. For accurate color separation, using a prism or other diffracting materials is far more effective.
cragar
Is it possible to pulse white light from a source and see colors .
Science news on Phys.org
Not unless you use a prism. However there are optical illusions which seem to produce color from pulsating white light. If you watch a rotating disc with alternating black and white stripes painted on it, your eye will tell you there are bands of colors.
like a benham top.
It's a very subtle effect and not a basis for actual 'colour synthesis' like you'd need for colour TV. The strength of the effect is very subjective and depends upon the individual. I reckon it works on the different time constants and linearities of the colour receptors in the eye.
A prism or some diffracting structure (an oil film or lines on a CD surface, for example) works much better!
