3-body solution in two dimensions
Loren Booda
Are there any exact solutions for two-dimensional projections of 3-body problems?
I really don't know anything about 3-body problems so I should probably just keep quiet, but...
If you have an unknown trajectory R(t) = <x(t),y(t),z(t)> it seems to me that if we could exactly solve for the trajectory in each of two planes we could solve the original trajectory exactly. In the z = 0 plane you would have R(t) = <x(t),y(t)> and in the y = 0 plane you would know R(t) = <x(t),z(t)> with perhaps a different parameterization. I would think having those two you could build the 3D version exactly, which, apparently, you can't do.
Disclaimer: The above may be worthless speculation.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
