Understanding Transvections:T_W:V->V Tv=v+w
  • Context: Graduate
  • Thread starter Thread starter Bacle
The discussion centers around the definition and properties of transvections in the context of finite-dimensional vector spaces. Participants explore the implications of the definition, the geometric interpretation, and the matrix representation of transvections, considering various fields and bases.
  • Some participants seek clarification on the definition of a transvection, specifically the conditions that define the mapping of vectors in a vector space V to a codimension-1 subspace W.
  • There is a question about whether the condition T(v) = v + w implies that vectors in V - W are mapped to V - W.
  • One participant suggests that the definition they found is ambiguous compared to another definition from a wiki source, which describes transvections in terms of direct sums and shear transformations.
  • Another participant argues that while the definition implies that V - W is mapped to V - W, it does not fully characterize transvections, citing an example that shows a mapping that satisfies the condition but is not a transvection.
  • There is a discussion about the matrix representation of transvections, with some participants asserting that it should always take the form of a shear matrix, while others contest this and suggest that the representation may vary.
  • One participant references a specific book that describes transvections and their properties, indicating a source for their definition.
Participants express differing views on the definition and properties of transvections, with no consensus reached on the sufficiency of the conditions provided or the appropriate matrix representation. Multiple competing definitions and interpretations remain in the discussion.
Participants note that the definitions and properties discussed may depend on the choice of basis and the field over which the vector space is defined. There are also references to the limitations of certain definitions in abstract vector spaces without standard notions of orthogonality.
Bacle
Understanding Transvections:T_W:V-->V Tv=v+w
Esteemed Algebraists:
Please help me understand better the definition of a transvection.
Let V be a finite-dimensional vector space, and let W
be a codimension-1 subspace of V . A transvection
is defined to be an invertible linear map T:V-->V
such that:
i) T|_W =1_W , i.e., the restriction of T to W
is the identity on W.
ii)For any v in V, T(v)=v+w ; w in W.
Condition i) is clear, but does condition ii) just say that
vectors in V-W are mapped to V-W?
Also: given a choice of basis for V, is the
matrix representation for V always that of
a shear matrix, i.e., a matrix with all diagonal
entries equal to 1, and all off-diagonal entries
except for exactly one equal to zero, i.e., a
matrix describing adding a multiple by k of one
row to another row?
I know this is the representation in vector spaces over R; is
it true for V.Spaces over any field F? ( I know all V.Spaces of same
dimension are isomorphic, but I don't know if that guarantees the result).
I was thinking of a simple example of a linear map from
R<sup>3</sup> to R<sup>3</sup>
preserving points of types (x,0,0) and (0,y,0). Then ii) above would say that, using the
standard basis {e_<sub>i</sub>; i=1,2,3}.
i) T(1,0,0)=(1,0,0)
ii) T(0,1,0)=(0,1,0)
iii) T(0,0,1)= (0,0,1)+(a,b,0) ; a,b in F
Is the intended meaning that for z in V-W, T(z) in V-W? Also, the representation of
this transvection does not seem to match that of a shear transformation, since it includes
the case of two non-zero entries a,b.
Any Ideas?
Thanks in Advance.
Thanks.
such that:
Where did you find this definition. I don't say it's incorrect, but it's a bit weird. The definition on wiki is a little better:
To be more precise, if V is the direct sum of W and W′, and we write vectors as
v = w + w′
correspondingly, the typical shear fixing W is L where
L(v) = (w + Mw′) + w ′
where M is a linear mapping from W′ into W.
I like it better because it's little less ambiguous.
No. Of course, the definition will still imply that V-W is mapped to V-W, but that's not quite enough. Take V=R^2 and W=R. Then T(1,0)=(1,0) and T(0,1)=(0,2) will satisfy that V-W is mapped to V-W, but it's not a transvection since there is no w in W such that T(0,1)=(0,2)+w.
Geometrically, a transvection maps W onto itself and translates points outside of W parallel to W.
row to another row?
I don't think this is true. If we follow wiki's definition, then a transvection always has the form
[tex]\left(\begin{array}{cc} I & M\\ 0 & I\end{array}\right)[/tex]
In my (limited) understanding of the topic, a shear matrix will represent a transvection, but not vice versa.
You could help me enormously in providing the reference you're using...
Hi, Micromass:
Sorry for the delay. I am going from the book "Classical Groups
and Geometric Algebra", by Larry C. Groves; a GTM book; mostly
pages 7 and 22. He describes transvections on a fin.-dim v.space
V; with invariant codimension-1 subspace W, as maps T:V-->V ,
with T|<sub>W</sub> =1<sub>W</sub> (i.e., map T:V-->V
restricts to the identity on W ), and , for any v in V, T(v)=v+w for
some w in W.
Grove goes on to show that transvections generate
both SL(V):={M in GL(V), Det(M)=1}, as well as the
symplectic group of V, given a symplectic form.
Yes, I understand that; but , since a transvection does map elements in V-W to elements in V-W, what additional condition do we need to characterize transvections? Maybe better to leave good-enough alone and accept T:v=v+w. So what else does the def. say that T:v-w is sent to v-w?
Well, actually, you would need a notion of orthogonality defined on your space; there are abstract vector spaces without an inner-product (thing homology over Z/2), without a standard ( if at all) notion of orthogonality.
Sorry to bring this up so late, I was just reviewing my posts.
  • · Replies 24 ·
