Differentiability of functions defined on manifolds
The discussion centers on the differentiability of functions defined on manifolds, specifically stating that a function f defined on a manifold M with values in a Banach space is differentiable if and only if it is differentiable as a map of manifolds. The concept of differentiability as a map of manifolds is clarified through the use of homeomorphisms, where a map \Phi:M→X is differentiable at a point x in M if the composition \Phi∘a-1 is differentiable. This highlights the relationship between manifold differentiability and the structure of Banach spaces.
  • Understanding of differentiable maps between Banach spaces
  • Familiarity with manifolds and their properties
  • Knowledge of homeomorphisms and their role in topology
  • Basic concepts of functional analysis, particularly Banach spaces
  • Study the properties of differentiable maps in the context of Banach spaces
  • Explore the concept of homeomorphisms in manifold theory
  • Learn about the implications of differentiability in functional analysis
  • Investigate examples of differentiable functions on specific manifolds
Mathematicians, particularly those specializing in differential geometry and functional analysis, as well as students studying advanced calculus and topology.
yifli
Quoted from a book I'm reading:
if f is any function defined on a manifold M with values in Banach space, then f is differentiable if and only if it is differentiable as a map of manifolds.
what does it mean by 'differentiable as a map of manifolds'?
Hi yifli! :smile:
(I assume that you have defined what a differentiable map is between Banach spaces).
Differentiability as a map of manifolds means:
Let [itex]\Phi:M\rightarrow X[/itex] be your map from M to a Banach space. And let [itex]x\in M[/itex], then x has an open neighbourhood which is homeomorphic to an open set of [itex]\mathbb{R}^n[/itex]. Thus there exists a homeomorphism [itex]a:U\rightarrow V[/itex] with U an open set in M that contaisn x and V open in [itex]\mathbb{R}^n[/itex].
Now, [itex]\Phi[/itex] is differentiable in x if and only if [itex]\Phi\circ a^{-1}[/itex] is differentiable.
  • · Replies 73 ·
9K
