Probability of a drawn card be a diamond given post conditions
by holemole
Tags: probability
holemole
holemole is offline
#1
Jul16-11, 05:24 AM
P: 10
Setting is like this: I have 52cards of 4 shapes. that's 13 each.
I take one card out and put it in a hat. now with 51card I draw 3 consecutive cards.
It happens to be that I picked 3 diamonds.
Now I want to find the probability of the card in the hat be a diamond.
My friend said it should be 10/49 since 3 diamonds are out, but I disagree.
I think those 3 diamonds with only one draw doesn't give enough information to favor other shapes than diamond at all, since the one card draw happened before any additional information, and 3 consecutive draws cannot affect previous draw in any way making the first draw independent of the second draw.
Phys.Org News Partner Mathematics news on Phys.org
Researchers help Boston Marathon organizers plan for 2014 race
'Math detective' analyzes odds for suspicious lottery wins
Pseudo-mathematics and financial charlatanism
Hurkyl
Hurkyl is offline
#2
Jul16-11, 05:57 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
Try considering another scenario:
I take one card out and put it in a hat. now with 51card I draw 13 consecutive cards.
It happens to be that I picked 13 diamonds.
pmsrw3
pmsrw3 is offline
#3
Jul16-11, 08:04 AM
P: 455
Quote Quote by holemole View Post
I understand what you're thinking. You're partly right. It is absolutely correct that, before you drew the additional cards, the probability of a diamond in the hat was 1/4. And you're right that the three subsequent draws can't affect the previous draw in any way. But you're wrong to think that that can't affect the probability characteristics of the first draw.
Probability is a function of information. It's about what you know and don't know. When you draw those three cards, your information changes, and therefore the probability changes.
Most probability paradoxes are about this. People have a tendency to think that probability exists independent of persons and information. They will naturally think that the probability that the card in the hat is a diamond is a characteristic of that physical setup, the card and the hat, and that if you don't change the card and the hat, the probability can't change. But that's wrong. The probability is about you and what you know. So there is no paradox in the idea that the probability changes when your information changes.
So, suppose you drew three diamonds, but you didn't show them to your friend, who is also there with you? What's the probability now? You have new information, so your probability is 10/49. But your friend has learned nothing new, so her probability is still 1/4. Which is right?
You're both right. Since probability depends on information, the same event came have different probabilities for different people with different information. The probability of a diamond in the hat is different for you and your friend. One again, the probability is not just a characteristic of the event.
Jaynte
Jaynte is offline
#4
Jul16-11, 08:14 AM
P: 67
This is the probability for picking 3 cards of diamonds if the one in the hat is Diamond or not:
[tex]\frac{3*\frac{13}{51}*\frac{12}{50}*\frac{11}{49}+1*\frac{12}{51}*\frac {11}{50}*\frac{10}{49}}{4}[/tex]
Jaynte
Jaynte is offline
#5
Jul16-11, 08:56 AM
P: 67
Sorry, i didnt read your question correctly. I would say that probability is 1/4
Jaynte
Jaynte is offline
#6
Jul16-11, 08:59 AM
P: 67
0% after you see the 13 diamonds, 1/4 before you see any diamonds.
holemole
holemole is offline
#7
Jul16-11, 09:14 AM
P: 10
i understand that information has changed. Nevertheless I'm not convinced that the information affects the original draw, since the population of the first draw doesn't necessarily change before I somehow pick 13 diamonds from 51 cards, which I didn't. I'm aware that if any new information that forces the population of the original event then it influences the probability like having 2 yellow balls and 2 red balls, and trying to find the probability that first ball is yellow WHEN second ball is yellow, which is not 1/2 but 1/3
holemole
holemole is offline
#8
Jul16-11, 09:15 AM
P: 10
Quote Quote by Jaynte View Post
Could you explain to me why this is the case?
pmsrw3
pmsrw3 is offline
#9
Jul16-11, 09:33 AM
P: 455
[QUOTE=holemole;3406228]i understand that information has changed. Nevertheless I'm not convinced that the information affects the original draw[quote]
The new information DOESN'T affect the original draw. I said so in my answer. The original draw either was or was not a diamond. If it wasn't a diamond, it will never be a diamond, no matter what you draw after. If it was a diamond, it will always be a diamond, no matter what you draw next (but you're guaranteed not to draw 13 more diamonds). And that is why part of Hurkyl's answer was "...1/4 before you see any diamonds".
But you are leaping to the conclusion that the information doesn't affect the probability of the first draw. That's completely different. "Doesn't affect the first draw" and "doesn't affect the probability of the first draw" are NOT the same. The first doesn't include the second. New information changes the probability without changing the physical event.
holemole
holemole is offline
#10
Jul16-11, 10:14 AM
P: 10
[QUOTE=pmsrw3;3406254][QUOTE=holemole;3406228]i understand that information has changed. Nevertheless I'm not convinced that the information affects the original draw
A probability, as far as I understand, is calculated by the number of events that has the results I'm trying to find(in this case shape=diamond) divided by total number of possible events. My red-yellow ball example adopts new information(second ball shoud be yellow) forces change in number of events I'm trying to find(from simply first draw being yellow to first AND second draw being yellow) and total number of possible events(from 4 to 3 since one ball is fixed).
However drawing 3 diamonds from 51 cards doesn't necessarily change those number of events since it is always possible to have first card as diamond AND pick 3 diamonds afterwards OR have first as other shape AND pick 3 diamonds after. Original number of possible events stays the same, since drawing 3 consecutive diamonds is just a random event in any case, whether there were 12 diamonds in 51cards or 13 diamonds. Number of events I'm trying to find didn't change either, since I didn't add any condition to the events I want to find.
pmsrw3
pmsrw3 is offline
#11
Jul16-11, 10:33 AM
P: 455
[QUOTE=holemole;3406306][QUOTE=pmsrw3;3406254]
Only if all events are equally probable. For instance, suppose I tried to tell you that the probability that a flipped coin comes up heads is 1/3, because it could come up heads, it could come up tails, or it could land balanced on the edge.
[tex]\frac{\text{number of events that has the results I'm trying to find}}{\text{total number of possible events}} = \frac{1}{3}[/tex].
You wouldn't agree with that, would you?
You can't just treat all possible events as equal.
It is possible, yes. But not equally probable. Diamond followed by three diamonds is less probable than non-diamond followed by three diamonds.
Rain on July 17, 3011 is "just a random event in any case". Supernova on July 17, 3011 is also "just a random event in any case". That doesn't mean they're equally probable.
holemole
holemole is offline
#12
Jul16-11, 10:58 AM
P: 10
Quote Quote by pmsrw3 View Post
first single card draw is consisted of equally probable events, isn't it?
This is completely true, but we're not trying to find number of events concerning first draw as diamond amongst total number of events where 3 consecutive draws after single draw are diamonds. 3 diamonds is not our 'condition'. It is just a result we stumbled upon randomly.
I'm not saying two random events are equally probable. I'm saying that 3 consecutive card draws turning out to be all diamonds is not a preset condition. If that's the case, answer IS 10/49. It can easily be calculated by finding number of events that has first draw as diamond AND has next 3 draws as diamonds as well which is 13*12C3, and divide this by total number of events that has 3 draws as diamonds but no condition on first draw which is 13*12C3+3*13*13C3.
However this is NOT what I'm trying to find. Original question never says to find probability that has 3 draws after the first one to be all diamonds. Thus two cases have different number of possible events.
Hurkyl
Hurkyl is offline
#13
Jul16-11, 11:12 AM
Emeritus
Sci Advisor
PF Gold
Hurkyl's Avatar
P: 16,101
Er, yes it is your condition. You saw three diamonds, so now all posterior probabilities ought to be conditioned on that fact. You will find that, out of all the experiments you do, less than one quarter of those where you drew 3 diamonds will have a diamond as the first card.
After drawing 3 diamonds, asking for the unconditioned probability is a purely hypothetical exercise.
(although it is important to be able to comprehend such hypothetical questions when appropriate)
Edit: A more blatant example that the posterior probabilities must be conditioned is this:
I flip over the top card, see that it's a diamond, and put it back. What are the odds the top card is a diamond?
Your line of reasoning would say 1/4.
disregardthat
disregardthat is offline
#14
Jul16-11, 11:20 AM
Sci Advisor
P: 1,690
Call the event that the card in the hat is diamond A, and drawing 3 consecutive diamonds while one randomly chosen card is in the hat B. We want P(A|B) which is 5/98, or approximately 5.1%. I think.
pmsrw3
pmsrw3 is offline
#15
Jul16-11, 11:24 AM
P: 455
Yes. And after the first draw, the probability of a diamond is 13/52 = 1/4.
Yes, it is a result that you stumbled on randomly. You seem to think that whenever you use the word "random", that means you can ignore it. But this is not true. Random events still carry information.
Suppose you were walking around and you saw a $100 bill on the sidewalk. Would you say, "Well, the probability of picking up a $100 bill on the sidewalk is practically zero. And, I was 'not trying to find number of events concerning' being able to pick up a $100 bill from the sidewalk. I 'just stumbled upon it randomly'. So the chance that I can now pick up a $100 bill from the sidewalk is still practically zero. Therefore, I'm not going to bend down and pick it up, because I know that the chance that I can pick up a $100 bill from the sidewalk is not worth the effort."?
Please, please, PLEASE, I beg you, stop saying, "It's just random". That's meaningless. Everything is "just random", to some degree or other. The idea that you can say "It's just random" and ignore it is WRONG.
As a matter of fact, that's wrong. The probability of drawing three diamonds after one diamond has been drawn is much less than 10/49.
No, you're right, the original question doesn't ask you to find the probability of drawing three diamonds after a first draw of a diamond. It asks you to find the probability that the first draw is a diamond, given that the three subsequent draws are diamonds. These are not the same number. But they ARE related (see Bayes' Theorem). It doesn't matter that this was not what you call a "preset condition". You've now drawn three diamonds. Whether you set out to do that or not is totally irrelevant. You now have that information.
The probability that the first draw was a diamond is multiplied by
[tex]
\frac{\text{probability of drawing three diamonds if first was diamond}}{\text{probability of drawing three diamonds if first was non-diamond}}
[/tex]
That's why it's relevant that the two probabilities aren't equal.
disregardthat
#16
Jul16-11, 11:29 AM
Sci Advisor
P: 1,690
[tex]
[/tex]
Shouldn't this be
[tex]
\frac{\text{probability of drawing three diamonds if first was diamond}}{\text{probability of drawing three diamonds if first was non-diamond or drawing three diamonds if first was diamond}}
[/tex]
pmsrw3
pmsrw3 is offline
#17
Jul16-11, 11:35 AM
P: 455
Quote Quote by disregardthat View Post
Shouldn't this be
[tex]
[/tex]
No -- notice I wrote that this is what the prior probability "is multiplied by". That is, I'm giving the factor by which it changes.
holemole
holemole is offline
#18
Jul16-11, 11:43 AM
P: 10
10/49 is the probability of the FIRST draw to be a diamond when three draws after the first are all diamonds.
Register to reply
Related Discussions
Card probability Set Theory, Logic, Probability, Statistics 10
Card Probability Calculus & Beyond Homework 0
deck of card probability Precalculus Mathematics Homework 6
Card game probability Set Theory, Logic, Probability, Statistics 2
Card Probability Set Theory, Logic, Probability, Statistics 10
