| New Reply |
Rotational Inertia: Front end of an airborn bike drops when brake is applied |
Share Thread | Thread Tools |
| Sep11-11, 01:36 PM | #1 |
So every mountain biker or motocross rider knows to never grab the front brake in the air. When you do the front end drops and can potentially ruin your day in a hurry. I figure that due to the loss of rotational inertia gravity accelerates the front wheel more rapidly, but I would like to see it described technically and mathematically... Any help?
| Sep11-11, 01:38 PM | #2 |
Admin
I don't think gravity has any effect here.
The lighter the wheel, the lesser the effect, probably. |
| Sep11-11, 02:13 PM | #3 |
For sure... The lighter the wheel the lesser the effect, also the heavier the bike the lesser the effect.
| Sep11-11, 03:37 PM | #4 |
| Sep11-11, 03:52 PM | #5 |
Ahh. Good point. That explains it thanks.
| Sep11-11, 04:03 PM | #6 |
Cm'on... keep some common sense...
Angular momentum and energy of front wheel has no significance at all! If you grab the front brake why in the air, you just stop the wheel immedaitely, and keep it blocked - as soon as you touch the ground you either flip, or fall into front wheel slip - what is not something bikers like :( |
| Sep11-11, 04:15 PM | #7 |
Admin
| Sep11-11, 04:18 PM | #8 |
No the front end definitely drops, or the bike rotates rather... If you don't believe me go try it. I'll go with A.T. on this one
| Sep11-11, 04:19 PM | #9 |
Admin
| Sep11-11, 05:54 PM | #10 |
I have no experience riding a bike like that, but if it is due to conservation of angular momentum, as I would also think it is, then braking the rear wheel "in-flight" should give the same effect everything else being equal. In addition, revving up the rear wheel should have the opposite effect and "pitch up" the bike. Are these effects something you would observe in practice?
| Sep11-11, 06:18 PM | #11 |
Recognitions:
| Sep11-11, 06:24 PM | #12 |
Mentor
You don't usually use the front wheel for adjusting your pitch because 1) it is lighter than your rear wheel and drive train, and 2) it is a little dorky to land with your front wheel not rotating. |
| New Reply |
| Thread Tools | |
Similar Threads for: Rotational Inertia: Front end of an airborn bike drops when brake is applied
| Effect of wheel diameter on bike disc brake performance? | Classical Physics | 17 | ||
| How come you have more stability riding a bike than standing still with a bike? | General Physics | 7 | ||
| band brake vs diff. band brake | Mechanical Engineering | 0 | ||
| Car Brake Performance Using Disc-Brake Variations | Mechanical Engineering | 2 | ||
| hiv mutations can result with hiv airborn? | Biology | 1 | ||
