Thread Closed
Suspended steel beam
Share Thread Thread Tools
Nov18-04, 03:34 PM   #1
Question
I'm having problems with what equation to use for this question:
A 1000 kg steel beam is supported by two ropes. Each rope has a maximum sustained tension of 6000N. Does either rope break?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov18-04, 03:55 PM   #2
Recognitions:
Homework Helper Homework Help
Draw a free body diagram.
The two tensions are directed along the ropes.
The sum of the tensions is directed upwards and has magnitude F=mg (m=mass of the beam).
Nov18-04, 04:01 PM   #3
Well, the weight causes a force of roughly 10*1000 = 10000 [N] on both ropes combined. But because of different angles, the forces caused by the ropes will not be the same. Let F1 be the force of the left rope (20 degree angle), and F2 the other force.
You know that the forces will have to keep the weight up, so the vertical components together must add up to 10000 [N] :
F1 sin[20] + F2 sin[30] = 10000
Now the horizontal components will be directed in opposite direction, and will, because of that, have to be of equal size. So:
F1 cos[20] - F2 cos[30] = 0
You can solve F1 and F2 from these equations, and check if any of the ropes will break.
Thread Closed
Thread Tools
Similar Threads for: Suspended steel beam
Thread Forum Replies
[Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ? Mechanical Engineering 2
Do you calculate the amount of load a beam can take based on when the beam cracks? Materials & Chemical Engineering 6
Steel Block Rotating On A Steel Table Introductory Physics Homework 1
suspended ropes Differential Equations 0
Judge Suspended Yes!!!!!!!!!!!!! Current Events 22
