How can we convert 1-hexene to cis-3-octene using alkynes as intermediates?
  • Thread starter Thread starter whatlifeforme
    Alkene Organic
To convert 1-hexene to cis-3-octene using alkynes as intermediates, the process involves first transforming the alkene into an alkyne. This can be achieved by removing hydrogens from the double bond, followed by the addition of a methyl group to the terminal carbon, potentially using CH3-Br for substitution. The synthesis requires careful consideration of maintaining the double bond's position while introducing the new alkyl group. The discussion emphasizes the need for a strategic approach to ensure the correct stereochemistry and structure of the final product. Overall, the synthesis pathway hinges on effective manipulation of the alkyne and alkene functionalities.
whatlifeforme
Organic: Alkene to Alkyne
I am trying to do a synthesis of 2-Octyne from 1-heptene. Conversion of the triple bond to a double bond is pretty easy, but i also have to add an alkyl group, and the double bond must remain on the original triple bond location.
Thus, so far thoughts:
1. remove hydrogens from double bond
2. add ch3 to terminal carbon to replace hydrogen.
CH3-BR ?
Question 2: Propose a synthesis of cis-3-octene starting from 1-hexene.
You need to review the http://courses.chem.indiana.edu/c341/documents/C341S2010CH7Alkynes.pdf"
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
