Why Are High Energies Needed to Break Particles and Observe Fine Structure?
  • Thread starter Thread starter jsmith613
    Physics Point
High energies are necessary to break particles into their constituents due to the strong force that binds them together, which requires significant energy to overcome. This force is much stronger than electromagnetic interactions, making it challenging to separate particles without high-energy collisions. Additionally, observing fine structure involves probing the internal details of particles, which also demands high energy to resolve these features. The discussion emphasizes the relationship between energy levels and the ability to manipulate and observe fundamental particles. Understanding these principles is crucial for grasping advanced concepts in particle physics.
jsmith613
explain why high energies are required to break particles into their constituents and to see fine structure
this is a point on the syllabus and I can't find an answer in the book
is it that the "strong force" holds constituent particles together
thus very high forces are needed to separate them?
this is the only point on the syllabus I don't quite get
could someone please run me through the main principles
thanks
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
