Matrices in power diagonal question
  • Thread starter Thread starter nhrock3
    Matrices Power
The discussion focuses on finding matrix B such that B3 = A, where A is defined as A = <14, 13; 13, 14>. The diagonal form of A is represented as D = <a, 0; 0, b>, with eigenvalues a and b. The user correctly identifies that U-1AU = D, where U consists of the orthonormal eigenvectors of A. The key steps involve calculating the cube root of A and resolving issues with the characteristic polynomial P(t) = (t - 14)2 - 169, which leads to confusion regarding the eigenvalues.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with diagonalization of matrices
  • Knowledge of matrix exponentiation
  • Proficiency in solving characteristic polynomials
  • Study the process of diagonalization in linear algebra
  • Learn about matrix cube roots and their properties
  • Explore the implications of non-invertible transformation matrices
  • Investigate the relationship between eigenvalues and characteristic polynomials
Mathematicians, students studying linear algebra, and anyone involved in matrix computations or theoretical physics will benefit from this discussion.
nhrock3
find B matrices so [tex]B^{3}=A=\left(\begin{array}{cc}14 & 13\\13 & 14\end{array}\right)[/tex]
,the diagonal form of A is [tex]D=\left(\begin{array}{cc}a & 0\\0 & b\end{array}\right)[/tex]
i got weird numbers so for convinience the eigenvalues are a,b
so there is U for which
[tex]U^{-1}AU=\left(\begin{array}{cc}a^{\frac{1}{3}} & 0\\0 & b^{\frac{1}{3}}\end{array}\right)^{3}[/tex]
i can find U
because A is simetric so U is consists of the orthonormal eigenvectors of A
what to do next,how to find B
i can find U
You have U-1AU = D, where D is a diagonal matrix whose entries are the eigenvalues of A.
It turns out that U-1A1/3U is a cube root of D (or D1/3), where D1/3 is also a diagonal matrix whose entries are the cube roots of the entries of D. In short, U-1A1/3U = D1/3.
To verify that U-1A1/3U is a cube root of D,
notice that (U-1A1/3U)3
= (U-1A1/3U)(U-1A1/3U)(U-1A1/3U)
= U-1A1/3UU-1A1/3UU-1A1/3U
= U-1A1/3A1/3A1/3U
= U-1AU = D.
In other words, if we cube U-1A1/3U, we get D, so U-1A1/3U is a cube root of D.
To get B, which is A1/3, multiply both sides of the equation U-1A1/3U = D1/3 on the left by U, and multiply both sides on the right by U-1.
i can find U
Why do you say the eigenvalues of A are 'weird'? They don't look weird to me. In fact they are both integer cubes. What did you get? I think you can do this whole exercise with easy numbers.
[tex]\left(\begin{array}{cc}14 & 13\\13 & 14\end{array}\right)[/tex]
the caracterstic polinomial
[tex]P(t)=(t-14)^{2}-169=t^{2}-28t+27[/tex]
t=1 t=27
for t=1 i get (-1,1) and for t=27 i got the same (-1,1)
so the transformation matrices is not invertible which is wrong
where is my mistake?
t=1 t=27
Your mistake is in what you didn't show. (-1,1) can't have an eigenvalue of both 1 and 27. Which is it?
10K
