Borne Haber Cycle/ Lattice Enthelpy for KBr
In summary: KBr is -113 kJ/mol.In summary, to draw the Borne Haber cycle for KBr, we need to understand the different steps involved in the formation of the compound and the energies associated with each step. The overall lattice enthalpy can be calculated using Hess's law by summing up the energies involved in each step. In the case of KBr, the lattice enthalpy is -113 kJ/mol.
dav1d
65
Draw the Borne Haber cycle for KBr
so the energy required to make the K into gas is +89kJ/mol
and it takes +420kJ/mol to take 1 electron from K
it takes +112kJ/mol to make Br a gas
it takes -342kJ/mol to give the Br an electron
and i was given -392 delta H subscrpit F superscript theta = -392kJ/mol (what does this mean?)
how do i calculate the lattice enthalpy?
Using Hess's law it should be the sum
So is it
89+420+112-342-392?
Dear student,
Thank you for your post. The Borne Haber cycle is a useful tool in understanding the formation of ionic compounds. To draw the Borne Haber cycle for KBr, we first need to understand the different steps involved in the formation of KBr.
Step 1: Formation of gaseous K (K(g))
The first step in the Borne Haber cycle is the formation of gaseous K from solid KBr. This requires energy, as indicated by the positive value of +89 kJ/mol.
Step 2: Ionization of gaseous K (K(g) → K+(g) + e-)
In this step, one electron is removed from gaseous K to form a K+ ion. This process requires energy, as indicated by the positive value of +420 kJ/mol.
Step 3: Formation of gaseous Br (Br(g))
The third step involves the formation of gaseous Br from solid KBr. This also requires energy, as indicated by the positive value of +112 kJ/mol.
Step 4: Electron affinity of gaseous Br (Br(g) + e- → Br-(g))
In this step, the gaseous Br atom gains an electron to form a Br- ion. This process releases energy, as indicated by the negative value of -342 kJ/mol.
Step 5: Formation of solid KBr (K+(g) + Br-(g) → KBr(s))
The final step in the Borne Haber cycle is the formation of solid KBr from gaseous K+ and Br- ions. This process releases energy, as indicated by the lattice enthalpy (-392 kJ/mol).
To calculate the lattice enthalpy, you can use Hess's law, which states that the overall enthalpy change of a reaction is independent of the route taken. This means that the sum of the energies involved in the individual steps should be equal to the overall enthalpy change.
In this case, the lattice enthalpy can be calculated as follows:
ΔHlattice = ΔH1 + ΔH2 + ΔH3 + ΔH4 + ΔH5
= (+89 kJ/mol) + (+420 kJ/mol) + (+112 kJ/mol) + (-342 kJ/mol) + (-392 kJ/mol)
= -113 kJ/mol
Therefore, the lattice enthal
FAQ: Borne Haber Cycle/ Lattice Enthelpy for KBr
1. What is the Borne Haber Cycle?
The Borne Haber Cycle is a thermodynamic cycle used to calculate the lattice energy of an ionic compound, such as KBr. It involves a series of steps that represent the formation of the compound from its constituent elements and the subsequent breaking of bonds to form gaseous ions.
2. What is lattice energy?
Lattice energy is the amount of energy required to break apart an ionic compound into its constituent ions in the gas phase. It is a measure of the strength of the electrostatic forces holding the ions together in the crystal lattice.
3. How is the lattice energy of KBr calculated using the Borne Haber Cycle?
The Borne Haber Cycle involves several steps, including the formation of gaseous ions from the elements, the formation of the ionic compound, and the dissociation of the compound into its constituent ions. The overall lattice energy is calculated by summing the energies of each step in the cycle.
4. What factors affect the lattice energy of KBr?
The lattice energy of KBr is affected by several factors, including the charge of the ions, the distance between the ions, and the size of the ions. Generally, as the charge of the ions increases, the lattice energy increases. As the distance between the ions increases, the lattice energy decreases. And as the size of the ions increases, the lattice energy decreases.
5. Why is the Borne Haber Cycle important in studying ionic compounds?
The Borne Haber Cycle provides a theoretical framework for understanding the formation and stability of ionic compounds. It also allows scientists to calculate the lattice energy of a compound, which is an important factor in determining its physical and chemical properties. This information is useful for various applications, such as in the design and development of new materials.
12K
22K
20K
