Discover the Mechanical Advantage of a Lever with Easy Physics
  • Thread starter Thread starter YouHelpIPass
    Physics
A lever with an effort arm of 2 meters and a mechanical advantage of 4 indicates that the load arm is 0.5 meters long. Conversely, a lever with a load arm of 0.8 meters and a mechanical advantage of 6 requires an effort arm of 4.8 meters. The discussion emphasizes the relationship between effort arm, load arm, and mechanical advantage in levers. Understanding these calculations is essential for applying the principles of physics effectively.
YouHelpIPass
A lever with an effort arm of 2 meters has a mechanical advantage of 4. What is the load arm's length?
A lever with a load arm of 0.8 meter has a mechanical advantage of 6. What is the length of the effort arm?
You first need to try, then we can help.
YouHelpIPass, please check your private messages for a message from me.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
