Interference in Thin Films, figuring out the phases
The discussion focuses on understanding phase changes in thin film interference, particularly when determining conditions for constructive interference (maxima). The problem involves light incident on a thin layer of material with specific refractive indices, and the goal is to find the thickness for the third least maximum. A key point raised is the need to add an additional λ/2 due to phase inversion upon reflection, leading to the equation 2L=(m+1/2)λ/n2. Participants emphasize the significance of using 2m+1 for odd numbers in this context, as it relates to achieving the necessary phase conditions for maxima. The conversation highlights the importance of visualizing wave propagation to understand the interference patterns.
emmy
I don't have a question on a specific problem, I am more caught up in the determination of the phases- I'll give a general problem to use as an example:
In Fig. 35-41, light is incident perpendicularly on a thin layer of material 2 that lies between (thicker) materials 1 and 3. The waves of rays r1 and r2 interfere, and here we consider the type of interference to be either maximum (max) or minimum (min). We are given:
n1=1.32
n2=1.75
n3=1.39
we want to find a max
for the 3rd least thickness of L (in nm)
λ=382nm (in air)
Figure:
rays are tilted for clarity
Since we want a maximum, the general equation for a maximum would be:
2L=(m+1/2)λ/n2
in the case of this problem, we add an additional λ/2 for the incidence of r1 on n2.
so my real question is this-
why is it that you multiply m by 2 to end up with 2m+1 in this case? when do you just use (m+1)λ vs (2m+1/2)λ
I've been reading and researching for hours now, so any help would truly be appreciated.
High-speed to slow speed you get a phase inversion.
http://www.kettering.edu/physics/drussell/Demos/reflect/reflect.html
... it has neat animations of the effect for string, you have to scroll down for the general.
That 2m+1 gives you an odd number - do you see why an odd number is needed?
The trick is to try drawing a wave as it propagates through the film. What happens if it's an even number?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
