| Thread Closed |
Impulse/force in pounds for the time frame |
Share Thread |
| Jan2-12, 05:24 PM | #1 |
A question please in three parts, need the numbers for the first before I can asked the next.
A Machine lowers from rest, 100 pounds under control, at 2m/s, for 1000mm. Then immediately stops the weight, and lifts it back up at 2m/s. At the transition from negative to positive, what impulse force in pounds, would be the maximum on the Machines components/parts, and for how long, untill the normal acceleration forces that would be on the components/parts if it lifted the weight from rest. Just in case I did not explain right. The force on the components/parts, lifting from rest would keep getting higher, lets go for every 10th of a second. Say from the lift at rest, the first 10th of a second would have at that vilocity ??? 105 pounds of force needed to lift the weight at that vilocity, then the next 10th of a second it may need 110 pounds as the vilocity went up, and more and more force would be needed to keep the vilocity going up, untill the decceleration. But what would be the impulse/force on/from the components/parts if the weight was lowered at the above vilocity, and for how long in 10ths or whatever in time would that higher force have to be untill the normal acceleration forces of the lift at rest. Thank you for your time and help. Wayne |
| Jan2-12, 06:04 PM | #2 |
Sorry, etited the above slightely, as the machine only has a maximum force to use of a 125 pounds. However if the weight has been falling that fast, and is stopped fast, the force on the machine will be well over the 125 pounds, even thou when it does slow down stop and relift, the weight will keep going down for a few mm’s, the force then on it will be far higher than the 125 pounds.
Wayne |
| Jan3-12, 09:58 AM | #3 |
Say Wayne,
1.) Bodies in motion cannot immediately (instantaneously) come to a stop; they must stop (decelerate) over a time interval. The impulse force depends on that time interval. 2.) why is your force measured in USA units and distances/velocities in SI units? You'll have to convert one to the other. 3.) If the time interval to stop is rather small, net impulse force will be very high; if the time is large, impulse force will be much less. 4.) If you are lifting a 100 pound body from rest with your machine rated at 125 pounds, to a constant speed of 2m/s (say 6.5 ft/s), then the max net force is 25 pounds, the acceleration is about 8 ft/s (per Newton 2), and the time interval during the accelerating phase must be about 1 second to stay within the limits of the machine. |
| Jan3-12, 12:03 PM | #4 |
Impulse/force in pounds for the time frameYes agreed, there would have to be a deceleration from the eccentric motion to the concentric, and in this/that time frame there would be the highest force used by the machine, but more important, in this very short deceleration phase there would be also the highest force “on” the machines parts/components. I am unable to work out the extra force from the weight coming down as of the acceleration component, or am I able to work out that force that will be on the machine, or the time frame that this deceleration too acceleration would take. I am no physicist, however this is one of a very large and long debate, all I can give are the weights, distances and other times frames. Some people are saying that the force on the machine will be as much as 300 pounds for a Milly second, I would not say that much. However, if it able to be worked out, it would be “very” interesting to find out it’s as ??? 180 pounds for .2 of a second, or what the real numbers are. Wayne |
| Jan3-12, 10:40 PM | #5 |
It really depends on the nature of the movement. If you were to raise the weight halfway up (1/4 m) in 1/4 second at constant acceleration, the acceleration would be 8 m/s^2, and since Fnet=ma, where a is 8 and m is about 4.5 kilos, then Fnet = 36 N up, which means that since the weight acts down at about 450 N, you got to push up at 486 N, or about 110 pounds. For the remainder of the upward thrust, you've got to decelerate to 0, and the weight helps you to decelerate, so the net force is 36 N down, which means you only need to apply a force of 414 N up, or about 90 pounds. Same on the downstroke, 90 pounds to the halfway point and 110 pounds back to the beginning.
But it is more likely in weightlifting that the acceleration phase takes place in a much shorter time period and distance, say 0.1 second for a distance of say 1/8 m; then its constant controlled velocity from this point until you decelerate near the top. In which case your initial acceleration is 25 m/s^2, Fnet = 110 N, or your force is 450 + 110 = 560 N, or about 125 pounds. These are just rough numbers for talking purposes only, but the bottom line is that the initial liftoff and final dropoff requires the greatest force, and perhaps over 150 pounds if you accelerated quickly over an even shorter time. |
| Jan5-12, 07:55 PM | #6 |
So am I right in saying, that on the above example, if we split the whole upward motion into 10 parts, and I accelerated up for 60% that it “may” look like this if we could plot my force somehow; 110 110 110 110 110 110 90 70 50 30 Then zero for the transition from positive to negative. Total, just for a reference number 900. So am I right in saying again, that on the above example, if we split the whole upward motion into 10 parts again, and I accelerated up for 60% But came off the eccentric to the concentric where the peak forces are, that it “may” look like this if we could plot my force somehow; 150 125 125 125 110 110 90 70 50 30 Then zero for the transition from positive to negative. Total, just for a reference number 985. As you “said” those numbers are just rough numbers for talking purposes only, but would the above be a rough estimation only ??? As some people are saying that if you lift the same weight “very” slow for say 166mm to very fast for say 1000mm in the same time frame, that the same total or overall force will be used by or and on the muscles, we all know that you have to use more energy doing anything faster in the same time frame, and as you fail far far far faster when doing faster repetitions, my opinion is that’s it’s you have to use more total or overall force ??? My EMG {a machine that reads the electrical activity in the muscles, the force or strength that the muscles are using} machine also gave me a higher readout force the faster repetitions. First is the most important, as it shows the EMG average muscle activity, or muscle force/strength used, as we know, the higher the average, the higher the total/overall force/strength used. 1, Fast 409, Slow 349, 2, Fast 437, Slow 346, 3, Fast 0.1, Slow 0.3, 4, Fast 0.6, Slow 0.7, 5, Fast 1104, Slow 1114, 6, Fast 146.0, Slow 193.4, 7, Fast 175.0, Slow 173.0, 1/ WRK This is the work average for the session measured in [µV] AVG microvolts. The average readings will vary from one patient to another. 2/ RST This is the rest average for the session measured in µV - Below AVG 4 µV a muscle is beginning to rest. 3/ AVG This is the average onset of muscle contraction measured in ONST seconds, readings below 1 second can be considered normal. 4/ AVG This is the average muscle release measured in seconds, RLSE readings below 1 second can be considered normal. 5/ W/R This is the average peak value measured in µV - The value will PEAK vary from one patient to another. 6/ WRK This is the average muscle deviation when contracting the AVDV muscle. Readings of below 20% of WRKAVG can be considered adequate, below 12% can be considered good. 7/ RST This is the average muscle deviation when the muscle is at rest. AVDV Below 4 µV a muscle is beginning to rest. MORE thank a big thank you for your time and help. Wayne |
| Jan5-12, 10:23 PM | #7 |
There is little value in guessing some possible values, because these guesses are made without knowledge of whether they are even likely or possible. It seems you are understanding the concepts just not the values of the numbers. The only cure for this, I believe, is with actual proven data, not with guesses as to what it could be if it were like this or that. Perhaps it would surprise you, or perhaps not, but guessing is no answer.
| Jan6-12, 03:35 AM | #8 |
What part of PhanthomJay's answer didn't you understand? He told you that for the first half you have to apply force equal with 110 pounds and for the second equal with 90 pounds. Just to prevent you from posting for pages and pages until the thread will be closed...I'll ask three questions: 1)Do you understand that when you lift a weight the average force is always equal with the weight? 2)Do you understand that when you lift a weight the average acceleration is always zero? 3)Do you understand that when you lift a weight the applied force over the duration of the lifting(or else the "total force" as you call it) is always equal with gravity's impulse? |
| Jan6-12, 10:39 AM | #9 |
UPSTROKE 110 110 110 110 110 90 DOWNSTROKE 90 90 90 90 90 110 110 110 110 110 ) |
| Jan6-12, 06:06 PM | #10 |
I have tried to tell you over and over, that {see what PhanthomJay states as well} when you lift a weight with more velocity or and acceleration, you have to use more force, and the more force you apply, the more the {not sure if I am saying this right, however I am try} weight will give an opposite reaction force, as to every action there is always an equal and opposite reaction, this opposite reaction, then puts more force on the pushing force, the muscles. Or we could say; The g-force, associated with an object in its acceleration. So we have accelerations produced by gravity, and non-gravitational forces, proper accelerations. I explained this in my Clay example, in other simple words, the faster you push up on and object, the more it pushes down on you. From a site; G-forces, when multiplied by a mass upon which they act, are associated with a certain type of mechanical force in the correct sense of the term force, and this force produces compressive stress and tensile stress. Such forces result in the operational sensation of weight. As there are two or more forces in action here, the force “from” the muscles, and the force “on” the muscles from the weight being moved. Wayne |
| Jan6-12, 06:51 PM | #11 |
Now it’s gets even more interesting. As many times I have thought about the deceleration, and would have thought your numbers were more correct, as when I do lift weight in this very explosive style, I would say it’s far more like that. As I “try” to accelerate up all the way, but as its harder to accelerate the more you accelerate, it’s getting harder, thus I have to use less force, and my body is sub concisely telling me I have to decelerate and stop and do the transition to the opposite direction soon in a Milly second. A question please, if you use more power, does that mean you use more overall or total force ??? Total or overall forces in the meaning as, if you only had a 100 pounds of force, or strength in my case, before your force runs out, and it can and does in the human body quite fast if you are lifting 80% Could I ask another question, it’s sort of on impulse. As my force lifts the weight faster and for more distance in the same time frame, some people think that when you lift slow, that when my force is on the deceleration, its where the slow moving people make up or balance out the forces, however I think no, as if this was true, then they should then also make up the difference in distance moved, but they don’t, meaning the lower force don’t make up or balance out the high force when they are on lower forces as of the decelerations. That I also think I may have proved that the slow lifting forces cannot make up or balance out the fast lifting forces with my clay theory. Put a piece of clay between your hand and the weight, lift a weight up and down one time for 3 seconds each way, then lift the weight up and six times at .5 of a second each way. The clay will be far more squashed on the faster reps, thus more force, or more important MORE tension is going onto the muscles ??? As the clay will feel all the forces of the slow and fast reps. Wayne |
| Jan7-12, 05:08 AM | #12 |
When you accelerate the muscle force is greater than the weight and when you decelerate is less than the weight.The acceleration is always balanced by the deceleration(average acceleration=zero) since you start and end at rest and on average you apply equal force with the weight. End of story. The magnitude that you call "total force" or "effect of force over time" can be described by the impulse and is always equal with gravity's impulse over the duration of the lifting regardless the lifting speed. |
| Jan7-12, 12:59 PM | #13 |
However, I will try and get data from the Myotest, or the Apt from the IPod, or buy a force plate; also we have the device/machine you said you were hoping to make. Yes they might surprise me or perhaps not. Thank you for your input and help. Wayne |
| Jan7-12, 01:01 PM | #14 |
Would like to add to this last question.
A question please, if you use more power, in the same time frame with the same weight, does that mean you use more overall or total force ??? Total or overall forces in the meaning as, if you only had a 100 pounds of force, or strength in my case, before your force runs out, and it can and does in the human body quite fast if you are lifting 80% Does also in a machine when the energy runs out. Wayne |
| Jan7-12, 01:40 PM | #15 |
Also you do not seem to believe EMG readings that are use all over the World. Wayne |
| Jan7-12, 05:51 PM | #16 |
If you don't have the intelligence to understand this...what's the point of the discussion? |
| Jan7-12, 11:31 PM | #17 |
| Thread Closed |
Similar discussions for: Impulse/force in pounds for the time frame
| most force/strength used in the same time frame | General Physics | 69 | ||
| Impulse question about Force and time | Introductory Physics Homework | 2 | ||
| Force vs. time graph (Impulse) | Introductory Physics Homework | 16 | ||
| Impulse and Force-Time Graph | Introductory Physics Homework | 2 | ||
| Velocity as a function of force/impulse/time. | Introductory Physics Homework | 2 | ||
