Is it possible to make water more diamagnetic?
  • Thread starter Thread starter IB Laker
    Diamagnetic Water
Water's diamagnetism is inherent to its molecular structure and cannot be altered without changing the substance itself. Adding powdered bismuth to water does not enhance its diamagnetic properties, as the fundamental characteristics of water remain unchanged. While bismuth is a diamagnetic material, its addition to water does not guarantee that plants will absorb it effectively. The discussion emphasizes that any modifications to water's properties are limited by its atomic structure. Ultimately, enhancing water's diamagnetism is not feasible through external additives.
IB Laker
Is it possible to make water more diamagnetic? If so, how? It would also help if the changes could be transferred to plants to affect the diamagnetic properties of the plant.
You can't make water more dimagnetic as dimagnetism is a property of the water molecules atomic structure which cannot be changed otherwise you change the nature of the substance.
Could i add powdered bismuth to the water and will the plant take up the bismuth? Or will nothing happen?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
