Did space missions use Newton's Theory of Gravity
In summary: Voyager 1 and 2 use a more modernized version of Cavendish experiments to obtain G. However, for Voyager 1, they also used a gravitational assist to Jupiter and then used the Jupiter's gravity to correct their trajectory. This gives us a very accurate determination of G.
neerajsu
Did Apollo space missions use Newton's Theory of Gravity or Einstein's theory of general relativity?
What about current space missions?? Also, I heard from my friends that nowadays people no longer use Newton's theory of gravity for the current space missions. How true is this?
And which one of these is majorly in practical use. Einsteins general relativity or Newton's Theory of Gravity??
In my school I was taught only about Newtons Theory of Gravity and I'm definitely not very well versed in Einstein's general relativity.. but I would like to get some expert opinions on this.
Another question.
I was explaining to my friend about calculating Earth's mass. I came to a suggestion that Earth mass could be calculated, but only with the knowledge of G, by say tossing a ball onto the ground and using Free fall acceleration(g) in Newtons theory of gravity equation. But without the knowledge of G how did they come to know about Earth's mass? How did they compute value of G in the first place? Cause I don't see a practical/empirical way to compute Gravitational pull between two objects.
Thanks
It is not quite an "either or" proposition. In practical applications Einstein's theory will manifest as small corrections to Newtonian predictions. If these are smaller than the level of precision for the application then they can be neglected.
For getting to the moon and landing on it, Newton's theory is sufficient. The precision of e.g. thrust and rocket motor on/off timing is too low for the application of Einstein's corrections to matter. The Newtonian course is plotted, and aimed at and any errors are measured and remediated via correction thrusts. (Note such issues as venting gasses affect trajectory more than relativistic factors.)
Now the GPS system needs to take Einstein's theory into account since they must measure time to very high precision over a long span of time. (To get a GPS guided bomb to land within 1 meter of the target requires better than 3 nano-second precision in time keeping.)
They used Newtonian gravity.
Except for missions to Mercury, there's no real reason to use general relativity. The errors resulting from using Newtonian gravity instead of general relativity are quite small. These errors build up over time, eventually becoming observable after a long period of time has passed. NASA does use general relativity to compute planetary ephemerides, but that's because the time spans are long. Space missions are short. For missions to the Moon such as the two satellites just sent into lunar orbit to better measure the Moon's gravity field, NASA still uses Newtonian mechanics.
Another question.
Thanks
The mass of the Earth cannot be assessed directly. What can be assessed directly is the product μe=G*Me. The standard gravitational parameter μe is very observable by looking at satellite orbits. This value is known to about 8 decimal places of accuracy. Compare that to G, which is known to only 4 places or so. G is one of the least well known of the fundamental constants. The Earth's mass is obtained by dividing μe by G. The uncertainty in the Earth's mass is almost entirely attributable to the uncertainty in G.
With regard to how G itself is assessed, that's typically done with a modernized variation of the Cavendish experiment.
What does this mean for missions like Voyager? If NASA uses GR to compute planetary positions, then I'd assume that they'd use it for these longer missions, but you've also stated that they wouldn't use it unless they were going to Mercury... unless there's a difference between using GR to figure out where you're going and to figure out the gravitational pull on the spacecraft on the way...
Another question.
Thanks
These are two really excellent questions, neerajsu.
It is so 'handy' to use Newton for calculations and then to make appropriate corrections later.
Your question about gravity really shows what a problem Scientists have. In many ways, Science has to 'pull itself up by its own bootstraps', building one measurement on a previous one. It's interesting to wonder what a civilisation near another, different star would do about measuring its environment. How many of their actual 'numbers' would turn out to be the same as ours. Obviously e and ∏ would be the same but what of the others - c, for instance?
Thank you for your answers guys. Cleared my doubts.
As you said, once you know G, you can calculate the mass of the Earth by measuring the acceleration of an object at the Earth's surface. For this reason, the Cavendish experiment, which measured G for the first time, is sometimes referred to as "weighing the Earth".
http://en.wikipedia.org/wiki/Cavendish_experiment
1. How did Newton's Theory of Gravity influence space missions?
Newton's Theory of Gravity played a crucial role in the development and success of space missions. It provided the foundation for understanding the motion of objects in space and the gravitational pull between celestial bodies.
2. Did space missions use Newton's Theory of Gravity to calculate trajectories?
Yes, space missions rely on Newton's Theory of Gravity to calculate the trajectories of spacecrafts and to plan their routes. This theory allows scientists to accurately predict the motion of objects in space and ensure the success of their missions.
3. How does Newton's Theory of Gravity explain the movement of planets and other celestial bodies?
Newton's Theory of Gravity explains the movement of planets and other celestial bodies by stating that every object in the universe exerts a gravitational force on every other object. This force is directly proportional to the mass of the objects and inversely proportional to the square of the distance between them.
4. Was Newton's Theory of Gravity used in the Apollo moon landing?
Yes, Newton's Theory of Gravity was used extensively in the Apollo moon landing mission. It was crucial in calculating the trajectories of the spacecrafts and ensuring they reached the moon and returned safely to Earth.
5. Is Newton's Theory of Gravity still relevant in modern space missions?
Absolutely, Newton's Theory of Gravity is still relevant in modern space missions and continues to be a fundamental principle in the field of astrophysics. It has been validated by numerous experiments and observations, and is still used to plan and execute space missions today.
  • Beyond the Standard Models
