Question on Feynman lectures volume 1 (wavelength and frequency)
The discussion revolves around understanding the derivation of equations related to wavelength and frequency in Feynman's lectures. The first equation, relating changes in wavelength to changes in angular frequency, is derived using approximations that become clearer with calculus. A key point is that the change in wavelength is inversely related to the change in frequency, which is highlighted through a function approximation. Additionally, the importance of the negative sign in the relationship between changes in frequency and wavelength is noted, emphasizing that it is often ignored when focusing on spectral line widths. Overall, the conversation underscores the need for calculus to fully grasp these concepts, while also providing intuitive explanations for those without a calculus background.
demonelite123
in chapter 32 section 4 on electromagnetic waves, near the end he writes since \lambda = \frac{2\pi c}{\omega} then \Delta\lambda = \frac{2 \pi c \Delta \omega}{{\omega}^2}. i understand the first equation he writes but then the second one i am having trouble convincing myself how he came up with that.
also earlier in chapter 30 on refraction, he also says the frequency is \nu = \frac{c}{\lambda} so \Delta \nu = \frac{c \Delta \lambda}{{\lambda}^2}. similarly i don't understand how he comes up with the second equation. he doesn't seem to explain it and it's not obvious to me how he got that. can someone help clarify this? thanks!
It sounds like you have not had calculus yet, when you do this will be much more clear. But in the mean time, you can still get it like this. If you have a function like f(x)=1/x (think of f as wavelength and x as frequency), and you want to know what changes in f will be, let x become x + dx, where dx is a small change in x, and call df the change in f that we are interested in. Then df = 1/(x+dx) - 1/x, correct? Now rewrite 1/(x+dx) as 1/x times 1/(1+dx/x), where dx/x << 1. Now here comes the key approximation, that works really well the smaller is dx/x:
I claim that 1/(1+dx/x) = 1-dx/x
to good approximation, and then note that if my claim is true, then df = dx/x2, as in the above formulae.
To check my claim, cross multiply, and note that the claim requires 1 = (1+dx/x)*(1-dx/x) = 1 - (dx/x)2. Can you see that (dx/x)2 is indeed a very small error in this equation, and gets really small as dx/x gets smaller? That's the whole idea-- the expressions you quote are not exact, but they are very good approximations that get better and better as the change in frequency you are considering gets smaller and smaller.
...then note that if my claim is true, then df = dx/x2, as in the above formulae.
I don't mean to nitpick, but just want to mention that if f(x) = 1/x, then (even without calculus) one can see that f(x) decreases when x increases, and f(x) increases when x decreases, which means the that the proportion relating a change in f to a change in x has to be negative. In fact (using calculus) the correct relation is df = - dx/x2. So Eq. (32.13), at the end of FLP Vol. I Chapter 32 section 3, which demonelite123 is asking about, and in which the minus sign is lacking, requires something more than calculus to explain it -- namely that, in this case, we are only interested in the width of the spectral lines so we can ignore the sign.
Mike Gottlieb
Editor, The Feynman Lectures on Physics
thank you both for your replies!
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
